./influxd.exe -config ./influxdb.conf
8888888 .d888 888 8888888b. 888888b.
888 d88P" 888 888 "Y88b 888 "88b
888 888 888 888 888 888 .88P
888 88888b. 888888 888 888 888 888 888 888 888 8888888K.
888 888 "88b 888 888 888 888 Y8bd8P’ 888 888 888 "Y88b
888 888 888 888 888 888 888 X88K 888 888 888 888
888 888 888 888 888 Y88b 888 .d8"“8b. 888 .d88P 888 d88P
8888888 888 888 888 888 “Y88888 888 888 8888888P” 8888888P”
[run] 2017/11/28 15:38:46 InfluxDB starting, version unknown, branch unknown, commit unknown
[run] 2017/11/28 15:38:46 Go version go1.8, GOMAXPROCS set to 2
[run] 2017/11/28 15:38:46 Using configuration at: ./influxdb.conf
[store] 2017/11/28 15:38:46 Using data dir: /home/yuyang/.influxdb/data
[filestore] 2017/11/28 15:38:46 \home\yuyang.influxdb\data\udp\AI301.AV\162\000000026-000000003.tsm (#0) opened in 1ms
[cacheloader] 2017/11/28 15:38:46 reading file \home\yuyang.influxdb\wal\udp\AI301.AV\162_00058.wal, size 0
[filestore] 2017/11/28 15:38:46 \home\yuyang.influxdb\data\udp\AI301.AV\198\000000007-000000001.tsm (#2) opened in 3.0001ms
[filestore] 2017/11/28 15:38:46 \home\yuyang.influxdb\data\udp\AI301.AV\198\000000006-000000002.tsm (#1) opened in 4.0002ms
[filestore] 2017/11/28 15:38:46 \home\yuyang.influxdb\data\udp\AI301.AV\198\000000004-000000003.tsm (#0) opened in 6.0003ms
[cacheloader] 2017/11/28 15:38:46 reading file \home\yuyang.influxdb\wal\udp\AI301.AV\198_00015.wal, size 5650286
[shard] 2017/11/28 15:38:46 \home\yuyang.influxdb\data\udp\AI301.AV\162 database index loaded in 31.0018ms
[store] 2017/11/28 15:38:46 \home\yuyang.influxdb\data\udp\AI301.AV\162 opened in 34.0019ms
[filestore] 2017/11/28 15:38:46 \home\yuyang.influxdb\data_internal\monitor\183\000000008-000000004.tsm (#0) opened in 1ms
[cacheloader] 2017/11/28 15:38:46 reading file \home\yuyang.influxdb\wal_internal\monitor\183_00038.wal, size 0
[shard] 2017/11/28 15:38:46 \home\yuyang.influxdb\data_internal\monitor\183 database index loaded in 5.0003ms
[store] 2017/11/28 15:38:46 \home\yuyang.influxdb\data_internal\monitor\183 opened in 8.0005ms
[filestore] 2017/11/28 15:38:46 \home\yuyang.influxdb\data_internal\monitor\185\000000008-000000004.tsm (#0) opened in 5.0003ms
[cacheloader] 2017/11/28 15:38:46 reading file \home\yuyang.influxdb\wal_internal\monitor\185_00038.wal, size 0
[shard] 2017/11/28 15:38:46 \home\yuyang.influxdb\data_internal\monitor\185 database index loaded in 3.0002ms
[store] 2017/11/28 15:38:46 \home\yuyang.influxdb\data_internal\monitor\185 opened in 13.0007ms
[filestore] 2017/11/28 15:38:46 \home\yuyang.influxdb\data_internal\monitor\187\000000008-000000004.tsm (#0) opened in 0s
[cacheloader] 2017/11/28 15:38:46 reading file \home\yuyang.influxdb\wal_internal\monitor\187_00039.wal, size 0
[shard] 2017/11/28 15:38:46 \home\yuyang.influxdb\data_internal\monitor\187 database index loaded in 14.0008ms
[store] 2017/11/28 15:38:46 \home\yuyang.influxdb\data_internal\monitor\187 opened in 16.0009ms
[filestore] 2017/11/28 15:38:46 \home\yuyang.influxdb\data_internal\monitor\189\000000011-000000002.tsm (#0) opened in 0s
[cacheloader] 2017/11/28 15:38:46 reading file \home\yuyang.influxdb\wal_internal\monitor\189_00039.wal, size 0
[shard] 2017/11/28 15:38:46 \home\yuyang.influxdb\data_internal\monitor\189 database index loaded in 3.0002ms
[store] 2017/11/28 15:38:46 \home\yuyang.influxdb\data_internal\monitor\189 opened in 6.0004ms
[filestore] 2017/11/28 15:38:46 \home\yuyang.influxdb\data_internal\monitor\191\000000009-000000002.tsm (#0) opened in 0s
[cacheloader] 2017/11/28 15:38:46 reading file \home\yuyang.influxdb\wal_internal\monitor\191_00037.wal, size 0
[shard] 2017/11/28 15:38:46 \home\yuyang.influxdb\data_internal\monitor\191 database index loaded in 11.0006ms
[store] 2017/11/28 15:38:46 \home\yuyang.influxdb\data_internal\monitor\191 opened in 13.0007ms
[filestore] 2017/11/28 15:38:46 \home\yuyang.influxdb\data_internal\monitor\193\000000009-000000002.tsm (#0) opened in 2.0001ms
[cacheloader] 2017/11/28 15:38:46 reading file \home\yuyang.influxdb\wal_internal\monitor\193_00038.wal, size 0
[shard] 2017/11/28 15:38:46 \home\yuyang.influxdb\data_internal\monitor\193 database index loaded in 3.0002ms
[store] 2017/11/28 15:38:46 \home\yuyang.influxdb\data_internal\monitor\193 opened in 9.0005ms
[filestore] 2017/11/28 15:38:46 \home\yuyang.influxdb\data_internal\monitor\195\000000009-000000002.tsm (#0) opened in 0s
[cacheloader] 2017/11/28 15:38:46 reading file \home\yuyang.influxdb\wal_internal\monitor\195_00038.wal, size 0
[shard] 2017/11/28 15:38:46 \home\yuyang.influxdb\data_internal\monitor\195 database index loaded in 14.0008ms
[store] 2017/11/28 15:38:46 \home\yuyang.influxdb\data_internal\monitor\195 opened in 16.0009ms
[filestore] 2017/11/28 15:38:46 \home\yuyang.influxdb\data_internal\monitor\197\000000002-000000002.tsm (#0) opened in 1ms
[cacheloader] 2017/11/28 15:38:46 reading file \home\yuyang.influxdb\wal_internal\monitor\197_00009.wal, size 10517240
on windows,I observed very high memory usage and I don’t kown why,Mine configuration file seems normal,blow are mine configuration file content.
reporting-disabled = false
bind-address = “:8088”
[meta]
dir = "/home/yuyang/.influxdb/meta"
retention-autocreate = true
logging-enabled = true
[data]
dir = "/home/yuyang/.influxdb/data"
wal-dir = "/home/yuyang/.influxdb/wal"
query-log-enabled = true
cache-max-memory-size = 573741824
cache-snapshot-memory-size = 26214400
cache-snapshot-write-cold-duration = "10m0s"
compact-full-write-cold-duration = "4h0m0s"
max-series-per-database = 100000
max-values-per-tag = 100000
trace-logging-enabled = false
[coordinator]
write-timeout = "10s"
max-concurrent-queries = 0
query-timeout = "10s"
log-queries-after = "0s"
max-select-point = 0
max-select-series = 0
max-select-buckets = 0
[retention]
enabled = true
check-interval = “30m0s”
[shard-precreation]
enabled = true
check-interval = "10m0s"
advance-period = “30m0s”
[admin]
enabled = true
bind-address = ":8083"
https-enabled = false
https-certificate = “/etc/ssl/influxdb.pem”
[monitor]
store-enabled = true
store-database = "_internal"
store-interval = “10s”
[subscriber]
enabled = true
http-timeout = "30s"
insecure-skip-verify = false
ca-certs = ""
write-concurrency = 40
write-buffer-size = 1000
[http]
enabled = true
bind-address = ":8086"
auth-enabled = false
log-enabled = true
write-tracing = false
pprof-enabled = true
https-certificate = "/etc/ssl/influxdb.pem"
https-private-key = ""
max-row-limit = 10000
max-connection-limit = 0
shared-secret = ""
realm = "InfluxDB"
unix-socket-enabled = false
bind-socket = “/var/run/influxdb.sock”
[[graphite]]
enabled = false
bind-address = ":2003"
database = "graphite"
retention-policy = ""
protocol = "tcp"
batch-size = 5000
batch-pending = 10
batch-timeout = "1s"
consistency-level = "one"
separator = "."
udp-read-buffer = 0
[[collectd]]
enabled = false
bind-address = ":25826"
database = "collectd"
batch-size = 5000
batch-pending = 10
batch-timeout = "10s"
read-buffer = 0
typesdb = "/usr/share/collectd/types.db"
security-level = "none"
auth-file = “/etc/collectd/auth_file”
[[opentsdb]]
enabled = false
bind-address = ":4242"
database = "opentsdb"
tls-enabled = false
batch-size = 1000
batch-pending = 5
log-point-errors = true
[[udp]]
enabled = true
bind-address = ":8089"
database = "udp"
batch-size = 5000
batch-pending = 10
read-buffer = 0
precision = “”
[continuous_queries]
log-enabled = true
enabled = true
run-interval = “1s”
