Hi Gurus,
I am trying to define a multi data center architecture and I need some one to help me.
Use Case:
- Multiple edge (few hundreds) data centers distributed globally running one Kubernetes cluster each
- One core data center
Now I want to collect monitoring data (matrix) from each k8s cluster and store them locally (edge). Then I want two actions on this data:
- Monitor local clusters/nodes and generate alerts using local database on edge
- Aggregate matrix and push to single core data center in scalable way for some time series analytics queries
- Single data base in “core” data center can ingest data from hundreds of edge data center? If not what ingestion layer I can use to receive data and buffer (kafka?) it before storing it in DB?
Please let me know what open sources systems can help me here in above 3 requirements.
Regards
