I have the below code:
var total_hits =
stream
|from()
.database('stats_prv')
.retentionPolicy('xtgpolicy')
.measurement('hotel_avail')
.groupBy('hus', 'hpr')
|window()
.period(5m)
.every(1m)
|sum('hit')
.as('hits')
It returns the sum of “hit” by “hus” and “hpr”. Now I want to get the TOP(10) of “hus” and “hpr” depending on “hits”.
The problem is that if I do a TOP(10, hits) after the SUM(), it returns the TOP(10) of each “hus” and “hpr”, but it isn’t what I want. I want only 10 rows, the 10 pairs of “hus” and “hpr” with more “hits”.
How can I get what I want?
Thanks and regards,
Marcos.
Try this:
var total_hits =
stream
|from()
|window()
.period(5m)
.every(1m)
|sum('hit')
.as('hits')
// Change groupBY to be nothing.
|groupBy()
|top(10, 'hits')
Hi @nathaniel,
Sorry but I think that I’m not quite understanding how Kapacitor works.
I’ve tried your recommendation and the results are:
Error:
Template:
Type: stream
Status: enabled
Executing: true
Created: 24 Apr 17 13:51 UTC
Modified: 24 Apr 17 13:51 UTC
LastEnabled: 24 Apr 17 13:51 UTC
Databases Retention Policies: ["stats_prv"."xtgpolicy"]
TICKscript:
var timeout_errors = stream
|from()
.where(lambda: "et" == 'Communication_error')
|window()
.period(5m)
.every(1m)
|sum('hit')
.as('hits')
|groupBy()
|top(1, 'hits')
|alert()
.slack()
.channel('#ntf-tgx')
.iconEmoji(':scream:')
.username('Kapacitor Alert - TIMEOUT')
.message('TOP12 {{ .Level }} High timeout rate for {{index .Tags "hus"}} - {{index .Tags "hpr"}}. Timeout rate: {{ index .Fields "rate"}}%. Total hits: {{ index .Fields "hits"}}. Timeout hits {{ index .Fields "fail"}}')
.crit(lambda: "hits" >= 1)
.noRecoveries()
.stateChangesOnly()
DOT:
digraph TOP12_timeout {
graph [throughput="0.00 points/s"];
stream0 [avg_exec_time_ns="0s" ];
stream0 -> from1 [processed="844876"];
from1 [avg_exec_time_ns="13.88µs" ];
from1 -> window2 [processed="30296"];
window2 [avg_exec_time_ns="2.421µs" ];
window2 -> sum3 [processed="660"];
sum3 [avg_exec_time_ns="778.138µs" ];
sum3 -> groupby4 [processed="660"];
groupby4 [avg_exec_time_ns="424ns" ];
groupby4 -> top5 [processed="660"];
top5 [avg_exec_time_ns="546.435999ms" ];
top5 -> alert6 [processed="659"];
alert6 [alerts_triggered="0" avg_exec_time_ns="35.414µs" crits_triggered="0" infos_triggered="0" oks_triggered="0" warns_triggered="0" ];
I have two questions:
Taking into account that the field “hit” is always > 0, why is there not any alert triggered?
According to the documentation:
Only tags that are dimensions in the grouping will be preserved; all other tags are dropped.
If I do a groupBy(), I will obtain the pairs of “hus” and “hpr” with more “hits”?
Thanks and best regards,
Marcos.
Can you add a |log() node just before the alert node and share the logs, so we can inspect what it happening?
@nathaniel this is the error:
[TOP12_timeout:alert10] 2017/04/26 07:44:26 E! error evaluating expression for level CRITICAL: no field or tag exists for hits
Ah yes I should have spotted that earlier. The |top node renames the field to top you can do this to preserve the name hits
|top(1, 'hits')
.as('hits')
Hi @nathaniel,
After rename ‘top’ as ‘hits’, alerts are triggered, but now the problem is that the fact of do a “groupBy()” causes that all the tags are dropped and I’m not able to know the 10 pairs of “hus” and “hpr” with more “hits”.
This is my message code:
|alert()
.slack()
.message('TOP12 {{ .Level }} High timeout rate for {{index .Tags "hus"}} - {{index .Tags "hpr"}}.')
.noRecoveries()
.stateChangesOnly()
But I receive the below alert (without neither his nor hpr):
Thanks!,
Marcos.
