I currently display all idocs with the next query
SELECT count(entry_status) FROM idoc_entry WHERE $timeFilter and entry_status=‘ERROR IN HYBRIS’ GROUP BY idoc_number, time($__interval)
this shows the amount of time each idoc had an ‘error in hybris’ entry_status. But i want to change it it to only display the top 10 idocs with the most error in hybris counts.
I tried this in my influx db
SELECT idoc_number, TOP(test,5) FROM (SELECT count(entry_status) as test FROM idoc_entry where entry_status = ‘ERROR IN HYBRIS’ GROUP BY idoc_number)
time idoc_number top
0 0000000979532169 24
I tried using this in grafana with the timefilters added but its not working, query used:
SELECT idoc_number, TOP(test,10) FROM (
SELECT count(entry_status) as test FROM idoc_entry WHERE $timeFilter and entry_status=‘ERROR IN HYBRIS’ GROUP BY idoc_number, time($__interval))
This is the result Screenshot - c1663f62136d57c902c764a57f11ace9 - Gyazo
