HELP: Can I Create Alerts (Checks, Notification Endpoint, Notification Rule) via API or any client lib?
Hello yes you can create any task with the API. And an alert is just a special type of task.
Here are the API docs for it:
https://docs.influxdata.com/influxdb/v2.0/api/#operation/PostTasks
Here’s a blog with a postman project you can use that includes everything you need:
Here’s info on how to create an alert in notification in a single task:
Here’s another community question with both:
