Having difficulties with 'window' related functions
Hello everyone,
I’ve been struggling with ‘windowing’ for the last 4-5 days and I just wasn’t able to solve the issue. So I decided to try my chances here…
I’ve seen a couple of topics related to my issue but they did not solve my problem.
What I’ve been trying to do is to windowing my query by ‘exact’ durations. window() and aggregateWindow() functions do not work the way I want.
With window()
t1 = data
    |> range(start: -1h, stop: now())
    |> window(every:15m)
    |> first()
    |> yield(name: "t1")
Result:
start _stop _time _value
2021-06-27T16:40:22.023043671Z 2021-06-27T16:45:00Z 2021-06-27T16:40:56Z v1
2021-06-27T16:45:00Z 2021-06-27T17:00:00Z 2021-06-27T16:45:56Z v2
2021-06-27T17:00:00Z 2021-06-27T17:15:00Z 2021-06-27T17:00:55Z v3
2021-06-27T17:15:00Z 2021-06-27T17:30:00Z 2021-06-27T17:15:54Z v4
2021-06-27T17:30:00Z 2021-06-27T17:40:22.023043671Z 2021-06-27T17:30:55Z v5
with aggregateWindow()
t1 = data
    |> aggregateWindow(every:15m, fn: first)
    |> yield(name: "t1")
Result:
_start _stop _time _value
2021-06-27T16:41:09.116567911Z 2021-06-27T17:41:09.116567911Z 2021-06-27T16:45:00Z v1
2021-06-27T16:41:09.116567911Z 2021-06-27T17:41:09.116567911Z 2021-06-27T17:00:00Z v2
2021-06-27T16:41:09.116567911Z 2021-06-27T17:41:09.116567911Z 2021-06-27T17:15:00Z v3
2021-06-27T16:41:09.116567911Z 2021-06-27T17:41:09.116567911Z 2021-06-27T17:30:00Z v4
2021-06-27T16:41:09.116567911Z 2021-06-27T17:41:09.116567911Z 2021-06-27T17:41:09.116567911Z v5
now the first problem arises here, I’m trying to get 15minute windows out of 1hour. so technically what I want is 4 exact evenly divided time blocks… WITHOUT dropping the _time values…
so here is an example of what I’m trying to get:
2021-06-27T16:40:22.023043671Z 2021-06-27T16:55:22.023043671Z T1 V1
2021-06-27T16:55:22.023043671Z 2021-06-27T17:10:22.023043671Z T2 V2
2021-06-27T17:10:22.023043671Z 2021-06-27T17:25:22.023043671Z T3 V3
2021-06-27T17:25:22.023043671Z 2021-06-27T17:40:22.023043671Z T4 V4
I was able to get this result by querying each 15 minute blocks one by one…
x1 = data
    |> range(start: -60m, stop: -45m)
    |> first()
    |> yield(....)
x2 = data
    |> range(start: -45m, stop: -30m)
    |> first()
    |> yield(....)
x3 = data
    |> range(start: -30m, stop: -15m)
    |> first()
    |> yield(....)
x4 = data
    |> range(start: -15m, stop: -0m)
    |> first()
    |> yield(....)
as you can guess, this is going to be a huge cumbersome because I will be using other selectors too… like last() min() max() and mean()
have been using this for the last 1-2 days. works fine for 1h periods, but what if I wanted to query last 12 hours?
and I’m not worried about visualizing the data. I’m sending results to my application to process further. so it is fine if the result includes multiple tables
Would be great if anybody can help me out with this…
thanks!
Hi! if i understand this correctly, I think all you need to do is align your time ranges to the top of the hour. For example, using the following:
import "date"
from(bucket: "telegraf")
  |> range(start: date.truncate(t: -1h, unit: 1h), stop: date.truncate(t: now(), unit: 1h))
  |> filter..
returns 4 rows, for 15, 30, 45, and 00 of the hour.
hello, thanks for the reply.
Yes that would work and I tried it actually but then I wouldnt be able to get the exactly last 1 hour data… For example, if the query runs at 17:14, then the the result would return records between 16:00 - 17:00 whereas I was expecting to see between 16:14 - 17:14
no?
ah ok. i think the “offset” param of the window function is helpful here. here’s an example of calculating it for your query. Someone else might have a more “elegant” way:
import "date"
every = 15m
offset = duration(v: string(v: uint(v: now()) - uint(v:date.truncate(t: now(), unit: every))) + "ns")
  |> range(start: -1h)
  |> filter...
  |> window(every: every, offset: offset)
  |> first()
  |> group()
I dont know what to say, man. you are a genius. thank you very much. this is exactly what I’ve been trying to do.
ughh I knew the ‘offset’ thing had something to do with this but couldn’t figure out how it worked exactly.
thank you again!
great to hear! i mean, there’s nothing obvious about any of that. i’ve opened this issue in the docs to make it more obvious for the next person: add note about calculating "unaligned" windows in the window function · Issue #2787 · influxdata/docs-v2 · GitHub
