I have a problem with how influxdb is grouping data. Let me start by saying that I am using a project called SBFSpot to read data from an invertor (with solar panels attached). Al this data is written to csv files. Telegraf reads these csv’s and put them inside influxdb. I read powergeneration, currents, voltage relay status,… The tool creates 3 csv’s:
- Month data: contains one line per day with power generated for that day.
- Spot data: Live data from the invertor like currents ac/dc, voltages ac/dc, power, relay status. Should be measured every minute. But often the values are just 0 (still looking into that).
- Day data, contains power generated in the last 5 min.
Data collection started on 8th november 2019. Before that there should be no data at al as I didnt have the solar panels yet. I also recently updated chronograf, influxdb and grafana and besides that I cleaned up a bit in the db and reimported all the data.
Now over to the issue. My goal is to show the power generated every month. So I need to make a sum of the last field of the file that contains the month data. To get there I used several steps. First show what data is present:
SELECT “kWh” FROM “file” WHERE “month”=~ /kas.lan*/ FILL(null)
time kWh
1573171200000000000 11.357
1573257600000000000 4.1
1573344000000000000 10.617
1573430400000000000 5.793
1576800000000000000 0.63
1576886400000000000 2.339
This looks fine to me. Start on 8th and ends on the 21th or 22. To calculate generated power last few months I’ll make a sum of the data and group by month. Time interval is 30 days:
SELECT sum(“kWh”) FROM “file” WHERE “month”=~ /kas.lan*/ GROUP BY time(30d) FILL(null)
time sum
1570752000000000000 15.456999999999999
1573344000000000000 119.755
1575936000000000000 36.087
Here is already something strange. Epoch time is Friday, October 11, 2019 12:00:00 AM but collection hadnt even started yet. When I group by month I get this:
SELECT sum(“kWh”) FROM “file” WHERE “month”=~ /kas.lan*/ GROUP BY time(30d), “month” FILL(null)
tags: month=kas.lan-201911.csv
time sum
1573344000000000000 93.5
1575936000000000000
tags: month=kas.lan-201912.csv
time sum
1573344000000000000 26.255
3 or 2 values for one month? When making the sum it seems to be correct though… Grafana does show me the correct graph using this query:
Chronograf does also show me 3 values:
“time”,“file.sum_kWh”
“2019-10-11T00:00:00.000Z”,“15.456999999999999”
“2019-11-10T00:00:00.000Z”,“119.755”
“2019-12-10T00:00:00.000Z”,“36.087”
Anyone know why this is happening?
