Grok pattern match but replace a character from result
Hi all
I am trying to extract the timestamp from a log file (Using the telegraf logparser input) but the date and time are separated by a semicolon. Is there a way I can make my Grok pattern work but replace the semicolon with a space ? - InfluxDB is erroring on parsing the timestamp because of the semicolon
Here is a sample from the log -
2019-11-18;05:10:55.954;INFORMATION;domain;test.user;2;1120;CheckUserExistsInGroup: No Entries Found In ExcludedGroups
this is my Grok pattern -
%{TS_CUST:timestamp:ts-“2006-01-02 15:04:05.999”};%{WORD:Status:tag};%{WORD:Domain:tag};%{USERNAME:username:tag};%{NUMBER:SessionID:int};%{NUMBER:ProcessID:int};%{WORD:Action}: %{GREEDYDATA:message}
TS_CUST %{YEAR}-%{MONTHNUM}-%{MONTHDAY};%{TIME}
and from grok debugger here is the output -
“timestamp”: [
“2019-11-18;05:10:55.954”
“Status”: [
“INFORMATION”
“Domain”: [
“domain”
“username”: [
“test.user”
“Action”: [
“CheckUserExistsInGroup”
“message”: [
“No Entries Found In ExcludedGroups”
I have been trying for ages to get rid of the semicolon between the date and time and replace with a ‘space’ in the ‘timestamp’ match as influxDB won’t accept the timestamp with the semicolon. It seems that the semicolon is not being ‘escaped’ in my pattern. Any help would be greatly appreciated
Have you tried
{TS_CUST:timestamp:ts-“2006-01-02;15:04:05.999”};%
Thanks rawkode that worked!
