Hi Team,
When queried in grafana using influxdb as data source , we are getting broken graphs. What is the cause is there any config change required.
Regards
Shashank
Hi Team,
Regards
Shashank
Not sure what broken graphs mean but you can run the same query using influx (command line). Under the database you can check, if it has same number of data points that you expect in graph. If they are no match investigate the measurement from Influxdb and the script/telegraf responsible for adding data.
