I spent the best part of a day figuring this out and thought it worth sharing.
I really like Grafana heatmaps (Grafana = organisational decision) to look at response times, showing the general trend and outliers in one place. Its easy to do in Prometheus, and I wanted to figure out how to do in Influx:
This is what I came up with.
Add some test data:
test duration=1 1620407874
test duration=1 1620407875
test duration=1 1620407876
test duration=10 1620407877
Create a task to generate the histogram, which this query replicates. In real life, you would run this every 5 minutes say looking back over the last 5 minutes. Run this a few times to generate the “downsample” data:
from(bucket: "test-bucket")
|> filter(fn: (r) => r["_measurement"] == "test")
|> filter(fn: (r) => r["_field"] == "duration")
|> histogram(bins: [0.0, 0.5, 1.0, 2.0, 5.0, 10.0, 30.0])
// make the histogram "non cumalative", Grafana doesn't offer the option like it does for Prometheus datasource
|> difference()
// add back time and change le to a string else to() fails
|> map(fn: (r) => ({_time:now(),_field:r._field, _value:r._value, le:string(v: r.le)}))
|> set(key: "_measurement", value: "test-downsample")
|> to(bucket: "test-bucket",tagColumns:["le"])
Now in Grafana, query:
|> filter(fn: (r) => r["_measurement"] == "test-downsample")
|> map(fn: (r) => ({_time:r._time,_field:r.le, _value:r._value}))
|> sort(columns:["_time"])
And now we can see a moving histogram, the le “1” has a count of 3 and le “10” has a count of 1. The dots appear where I run the query to downsample the data:
If i missed an easier way to do this, please let me know!
