I basically have a template for my grafana dashboard with prometheus and I’m trying to translate those to influxdb.
Particularly, I have a query,
“histogram_quantile(0.98,sum(rate(resilience4j_circuitbreaker_calls_seconds_bucket{application=~”$application", instance=~"$instance", name=~"$circuitbreaker_name"}[1m])) by (le))" in prometheus.
I need this same dashboard using influxdb. Any help would be amazing!
Alteranatively, is there an easy way to translate prometheus dashboards to infuxdb?
