The tutorial thing asks the user to copy this (cut)
point := influxdb3.NewPointWithMeasurement("census").
AddTag("location", data[key]["location"].(string)).
AddField(data[key]["species"].(string), data[key]["count"])
But *Point type has no function for AddTag and AddField, I changed it to SetTag and SetField and then it worked. Plz fix
SetTag("location", data[key]["location"].(string)).
SetField(data[key]["species"].(string), data[key]["count"])
Thanks for reporting this. Can you provide a link to where you found the tutorial. I’m sure @Anaisdg will take a look when back from leave.
Its the tutorial when you do client/golang after add data to new bucket, in the code snippets it asks you to copy to your local machine
@Anaisdg , did you see this one?
Hello @FixTestRepeat And @wrvclark I believe this has been corrected thank you!
Still seeing this at new-user-setup/golang
Also the “os” package should be imported and the “fmt” package should not be imported
agav
7
I still see the same errors in the Go tutorial InfluxDB. See screenshot attached.
