I am trying to setup a lab switch and monitor it through the inputs.gnmi plugin but when I start the process I am getting no response. I assume it is due to permission being able to login to the device but is there a specific log where I can view that? I started telegraf with --test and --debug but there were no results it just gave the “loading config: gnmi.conf” prompt and then stopped. I checked
I just opened this same topic and question a few days ago, so far I haven’t found an answer but I do have a case open with our switch vendor. I will let you know when I make progress.
