I got a Proxmox server running, and under Datacenter I am able to use Metrics, and Influxdb.
That is it, no version no nothing.
As you can see I am not able to change org or bucket, I have done what this page suggests:
https://pve.proxmox.com/wiki/External_Metric_Server
Should I create an proxmox reciver bucket? And an proxmox org? If so how do I do that?
Hi @mattias ,
Hope you are doing well. A couple of things to check:
Did you add the UDP configuration to the InfluxDB config file and restart it?
When you created your InfluxDB instance did you log in via the UI to setup?
I assume since you are using buckets that you are using InfluxDB 2.X
How are you running your InfluxDB instance? Via Docker containers or installed directly on host?
If not:
- login via http://:8086
- create proxmox org and proxmox bucket. Generate the token for the bucket aswell.
