I’ve got a Kubernetes cluster running some Springboot applications instrumented with the Jolokia JVM agent plugin. I’m running Telegraf as deployment alongside my Java containers to get the JVM metrics from Jolokia.
The problem I’m having is that the Jolokia plugin always reports the hostname as the Telegraf container running Telegraf collecting the Jolokia metrics and I want the payloads to contain the actual container hostname which is running the Jolokia agent. I’m aware of the inputs.server portion of the config where you can specify a name and host but the problem is when I have Jolokia running against multiple pods I can’t hardcode in the specific values.
For what it’s worth here here is my config map. Is it possible to get the container hostname within the payloads?
apiVersion: v1
kind: ConfigMap
metadata:
data:
telegraf.conf: |+
[global_tags]
datacenter = "aws"
[agent]
interval = "10s"
round_interval = true
metric_batch_size = 1000
metric_buffer_limit = 10000
collection_jitter = "0s"
flush_interval = "10s"
flush_jitter = "0s"
precision = ""
omit_hostname = false
[[outputs.http]]
<ommitted>
[[inputs.jolokia2_agent]]
urls = ["http://sample-tomcat.default.svc.cluster.local:8778/jolokia"]
name_prefix = "tomcat."
[[inputs.jolokia2_agent.metric]]
name = "OperatingSystem"
mbean = "java.lang:type=OperatingSystem"
paths = ["ProcessCpuLoad","SystemLoadAverage","SystemCpuLoad"]
name = "jvm_runtime"
mbean = "java.lang:type=Runtime"
paths = ["Uptime"]
name = "jvm_memory"
mbean = "java.lang:type=Memory"
paths = ["HeapMemoryUsage", "NonHeapMemoryUsage", "ObjectPendingFinalizationCount"]
name = "jvm_garbage_collector"
mbean = "java.lang:name=*,type=GarbageCollector"
paths = ["CollectionTime", "CollectionCount"]
tag_keys = ["name"]
name = "jvm_memory_pool"
mbean = "java.lang:name=*,type=MemoryPool"
paths = ["Usage", "PeakUsage", "CollectionUsage"]
tag_keys = ["name"]
tag_prefix = "pool_"
name = "GlobalRequestProcessor"
mbean = "Catalina:name=*,type=GlobalRequestProcessor"
paths = ["requestCount","bytesReceived","bytesSent","processingTime","errorCount"]
tag_keys = ["name"]
name = "JspMonitor"
mbean = "Catalina:J2EEApplication=*,J2EEServer=*,WebModule=*,name=jsp,type=JspMonitor"
paths = ["jspReloadCount","jspCount","jspUnloadCount"]
tag_keys = ["J2EEApplication","J2EEServer","WebModule"]
name = "ThreadPool"
mbean = "Catalina:name=*,type=ThreadPool"
paths = ["maxThreads","currentThreadCount","currentThreadsBusy"]
tag_keys = ["name"]
name = "Servlet"
mbean = "Catalina:J2EEApplication=*,J2EEServer=*,WebModule=*,j2eeType=Servlet,name=*"
paths = ["processingTime","errorCount","requestCount"]
tag_keys = ["name","J2EEApplication","J2EEServer","WebModule"]
name = "Cache"
mbean = "Catalina:context=*,host=*,name=Cache,type=WebResourceRoot"
paths = ["hitCount","lookupCount"]
tag_keys = ["context","host"]
apiVersion: apps/v1
kind: Deployment
metadata:
spec:
selector:
matchLabels:
app: telegraf
minReadySeconds: 5
template:
metadata:
labels:
app: telegraf
spec:
containers:
- image: telegraf:1.10.0
volumeMounts:
- name: telegraf-config-volume
mountPath: /etc/telegraf/telegraf.conf
subPath: telegraf.conf
readOnly: true
volumes:
configMap:
