Get identifier rejected error while using outputs.mqtt(Mosquitto version is 2.0.12)
Hi ,
I face one issue with outputs.mqtt plugin.
Step 1: Clone the source code from GitHub - influxdata/telegraf: The plugin-driven server agent for collecting & reporting metrics. and git checkout the tag v1.19.3. I use make to get my own telegraf daemon.
Step 2: docker pull eclipse-mosquitto:1.5
Step 3: docker run -d --name mqttserver eclipse-mosquitto:1.5
Step 4; docker inspect mqttserver and get the container ip.
Step 5: Revise telegraf.conf. Add the above ip to configuration.
Step 6: ./telegraf -config /etc/telegraf/telegraf.conf --debug true, and the result is working well.
Step 7: stop the telegraf, and docker stop mqttserver && docker rm mqttserver.
Step 8: docker run -d --name mqttserver2 eclipse-mosquitto:2.0.12.
Step 9: Since mqttserver2 only allows localhost connection, we have to revise configuration file.
Add the following into /mosquitto/config/mosquitto.conf
listener 1883
allow_anonymous true
Step 10: docker restart mqttserver2
Step 11: docker inspect mqttserver2 to get container ip.
Step 12: Revise telegraf.conf. Add the above ip to configuration.
Step 13: ./telegraf -config /etc/telegraf/telegraf.conf --debug true, and you will see
error was ‘identifier rejected’
The workaround is not using mosquitto2.0.12 or revert this solution Disable keepalive in mqtt output. (#3779) · influxdata/telegraf@8c932ab · GitHub
Does anyone have comment for this?
Hi Ruke,
I hope you are doing well. So if I understand your use-case a little further you are spinning up a mosquito server on an isolated docker network? i.e. not binding ports to host / running in network mode host? Are you also building telegraf as a docker container in this isolated docker network or running this at a host level. My advise would be to bind the 1883 port to your host network like so:
docker run -d --name mqttserver2 -p 1883:1883 eclipse-mosquitto:2.0.12
Then you will be able to use http://localhost:1883 as shown within the telegraf docs. If there is a requirement for isolating the MQTT server within a docker network let me know.
Hi @Jay_Clifford
For mqtt:
docker exec -ti mqttserver2 sh
/ # ip ro
default via 10.0.5.1 dev eth0
10.0.5.0/25 dev eth0 scope link  src 10.0.5.4
For telegraf:
It’s another alpine container which also runs on the same host.
telegraf.conf is something like the following
 [[outputs.mqtt]]
   servers = ["10.0.5.4:1883"] # required.
Since all container are binding to the some bridge, I can ping mqttserver2 from my telegraf container.
As you can see, if I connect to mosquitto 1.5, I will see the following log
2021-09-15T01:33:53Z D! [outputs.mqtt] Buffer fullness: 0 / 10000 metrics
2021-09-15T01:34:03Z D! [outputs.mqtt] Buffer fullness: 0 / 10000 metrics
2021-09-15T01:34:13Z D! [outputs.mqtt] Buffer fullness: 0 / 10000 metrics
2021-09-15T01:34:23Z D! [outputs.mqtt] Buffer fullness: 0 / 10000 metrics
2021-09-15T01:34:33Z D! [outputs.mqtt] Buffer fullness: 0 / 10000 metrics
2021-09-15T01:34:43Z D! [outputs.mqtt] Buffer fullness: 0 / 10000 metrics
2021-09-15T01:34:53Z D! [outputs.mqtt] Buffer fullness: 0 / 10000 metrics
From my mqttserver, I can see the following log.
1631670208: Client Telegraf-Output-uzAAh disconnected.
1631670253: New connection from 10.0.5.2 on port 1883.
1631670253: New client connected from 10.0.5.2 as Telegraf-Output-krVXp (c1, k30).
1631670253: No will message specified.
1631670253: Sending CONNACK to Telegraf-Output-krVXp (0, 0)
1631670283: Received PINGREQ from Telegraf-Output-krVXp
The behavior with mosquitto 1.5 is working well, but is not working for mosquitto 2.0.12.
Hi Ruke,
I managed to reproduce your issue this morning with a simuler setup nice catch. I used Node-Red as a secondary tool to test connectivity which appears to work fine. Have you submitted an issue on the Telegraf GitHub yet? Issues · influxdata/telegraf · GitHub
If not we can add your issue there and one of the Telegraf team can take a look.
Do you receive the same issue when using 2.0.12 with authentication?
Thanks,
Jay
Hi @Jay_Clifford
No, I have not posted this issue on Telegraf Github, but I see a similar discussion on Mosquitto.Keep alive 0 results in 'identifier rejected' · Issue #2309 · eclipse/mosquitto · GitHub.
Ans: I have tried using tls, and got the same issue ‘identifier rejected’. I will try using authentication mechanism and update.
By the way, if I mark the code from telegraf plugins/outputs/mqtt/mqtt.go.
opts.KeepAlive = 0
The result is good for both mosquitto 1.5 and 2.0.12.
Hi Ruke,
I have reached out to one of our Telegraf team members to see if they have any ideas. I have seen an issue like this in the past where the rejection was due to a bad clientID but this seems to not be the case. I think next steps will be to turn this into an issue.
Hi @Ruke_Chen,
Thanks for the detailed issue! If you could open a related issue in Telegraf that would be great.
I think it should be a simple fix based on the information you’ve provided around the opts.KeepAlive setting we have changed. If you were interested in submitting a PR that would also be welcomed. If not someone from the team will take a look.
Hi @helenosheaa
Sure I will open an issue on Telegraf GitHub. Since opts.KeepAlive is related to this commit Disable keepalive in mqtt output. (#3779) · influxdata/telegraf@8c932ab · GitHub , I have no idea how this affect . I think I open an issue first, and check the feedback.
Hi all,
A related issue is created earlier . Mosquitto 2.0.12 - Keep alive 0 results in 'identifier rejected · Issue #9763 · influxdata/telegraf · GitHub. So I add my comment in this post.
