Hi There,
I have 2 databases (db1 and db2) with the same measurement names. What I want is using influxql I wanna select value from a measurement on a specific db.
For example…
select value from measurement on db1
Ideally most of CLI use the “use db1” statement and then do the “select value from measurement” how can I achieve this using only one statement?
Is it possible?
Influxdb version is 1.8
Thanks and regards,
