I have an influxDB testdb where, I am trying a SELECT query on 4 different measurements with different fieldtype.I am able to query more than measurements successfully but when it comes to combining multiple measurements with different fieldType, influxDB only returns results for one fieldType.
Setup
> create database testdb
> use testdb
Using database testdb
> insert rpm,path=P1 data=200
> insert rpm,path=P2 data=100
> insert rpm,path=P1 data=300
> insert load,path=P1 data=77
> insert load,path=P1 data=89
> insert mode,path=P1 data="AUTOMATIC"
> insert mode,path=P2 data="MANUAL"
> insert execution,path=P1 data="ACTIVE"
Now I have 4 measurements namely, rpm, load, mode, execution. Their fieldType are:
> show field keys on testdb
fieldKey fieldType
data string
fieldKey fieldType
data float
fieldKey fieldType
data string
fieldKey fieldType
data float
What I can do
I am able to get results successfully from mode than one measurements of same fieldType.
> select last(data) from mode, execution
time last
1564000155710480300 ACTIVE
time last
1564000155694460700 AUTOMATIC
> select last(data) from rpm, load
time last
1564000155650446100 89
time last
1564000155620293100 300
Problem
I am not able to combine all 4 measurements into one single query. the below query should return results for all 4 measurements, instead it returns results for only float type.
> select last(data) from mode, execution, rpm, load
time last
time last
If I change the order, I get the same result:
> select last(data) from rpm, load, mode, execution
time last
time last
Is there a way so that I can get the result for string and float type in one result set?
