Get data to InfluxDB2 via Telegraf OPC UA Connection from UaExpert Client - Simple Example not working
For 1st testing the shown value from “ncounter” I want to import to InfluxDB2 via a Telegraf.conf.
from the UaExpert Client software.
Telegraf config file looks like this (simplified):
[[outputs.influxdb_v2]]
urls = [“http://localhost:8086”]
token = “$INFLUX_TOKEN”
organization = “MasterOrg”
bucket = “OPC_UA_Test”
[[inputs.opcua]]
name = “opcua”
endpoint = “opc.tcp://localhost:4840”
connect_timeout = “10s”
request_timeout = “5s”
security_policy = “None”
security_mode = “None”
auth_method = “Anonymous”
nodes = [
{name=“opc”,namespace=“3”,identifier_type=“s”,identifier=“nCounter”,data_type=“int”},
I get the following Errors in my CLI (Windows10):
2021-10-26T13:27:04Z I! Failed to load certificate: open /etc/telegraf/cert.pem: Das System kann den angegebenen Pfad nicht finden.
2021-10-26T13:27:04Z E! [telegraf] Error running agent: could not initialize input inputs.opcua: unable to find suitable server endpoint with selected sec-policy and
sec-mode
I already unlocked the port in my firewall. It’s all local installed for testing.
Can anybody help me how to fix this?
Regards,
Manfred
Anybody an idea how to get that certificate & key in the Telegraf.config?
Do I need to copy something in the folder manually?
Auotmatic generating is not working.
  ## Security policy, one of "None", "Basic128Rsa15", "Basic256",
  ## "Basic256Sha256", or "auto"
  security_policy = "Basic256Sha256"
  ## Security mode, one of "None", "Sign", "SignAndEncrypt", or "auto"
  security_mode = "Sign"
  ## Path to cert.pem. Required when security mode or policy isn't "None".
  ## If cert path is not supplied, self-signed cert and key will be generated.
  certificate = "/cert.pem"
  ## Path to private key.pem. Required when security mode or policy isn't "None".
  ## If key path is not supplied, self-signed cert and key will be generated.
   private_key = "/key.pem"
I don’t think those absolute paths (starting with “/”) are correct. Try
specifying the full path to the files, such as “/etc/telegraf/cert.pem” etc.
Antony.
Yes you’re right I already corrected the paths (to the Telegraf folder).
But my issue is where to get this files?
I want to connect to a TwinCat3 Server
TwinCat requires a Security certificate.
They are not auto-generated for Telegraf.
The acces is denied without these cert/key.
I tried to copy this certificates from the TwinCat-Folder, but not sure whre to find the “key”.
This is what the CLI responds after starting Telegraf:
2021-10-28T13:00:58Z I! Failed to load certificate: tls: failed to find certificate PEM data in certificate input, but did find a private key; PEM inputs may have been
switched
2021-10-28T13:00:58Z E! [inputs.opcua] Error in plugin: error in Client Connection: opcua: invalid channel config: Security policy
'http://opcfoundation.org/UA/SecurityPolicy#Basic256Sha256' requires a private key
2021-10-28T13:00:58Z E! [telegraf] Error running agent: input plugins recorded 1 errors
FYI complete Telegraf.conf looks like this:
### Configuration for telegraf agent
[agent]
interval = "10s"
round_interval = true
metric_batch_size = 1000
metric_buffer_limit = 1000
collection_jitter = "0s"
flush_interval = "10s"
flush_jitter = "0s"
precision = "ns"
debug = false
quiet = false
#hostname = ""
   urls = ["http://localhost:8086"]
  token = "$INFLUX_TOKEN"
  organization = "MasterOrg"
  bucket = "OPC_UA_Test"
[[inputs.opcua]]
  ## Metric name
  name = "opcua"
  ## OPC UA Endpoint URL
  endpoint = "opc.tcp://Manu:4840"
  ## Maximum time allowed to establish a connect to the endpoint.
  connect_timeout = "10s"
  ## Maximum time allowed for a request over the estabilished connection.
  request_timeout = "5s"
  #certificate = "/cert.pem"
  certificate = "/Program Files/Telegraf/cert.pem"
  # private_key = "/key.pem"
  private_key = "/Program Files/Telegraf/key.pem"
  ## Authentication Method, one of "Certificate", "UserName", or "Anonymous".  To
  ## authenticate using a specific ID, select 'Certificate' or 'UserName'
  auth_method = "Anonymous"
 nodes = [
{name="nCounter",namespace="4",identifier_type="i",identifier="MAIN.nCounter",data_type="int"},
