Grfana V10.0
InFluxDB 2.7
I need to store the following data per site - “Site name” “battery” “latitude” “level” “longitude”.
So I have a bucket flood with the following structure. (Cardinality possibly high)
I need to display the last points for each site on a Grafana GEO map. Use the query
from(bucket: "flood")
|> filter(fn: (r) => r["tag1"] == "Kwezimbovu" or r["tag1"] == "Landulwazi" or r["tag1"] == "Mabedlana")
|> filter(fn: (r) => r["_field"] == "Site" or r["_field"] == "battery" or r["_field"] == "latitude" or r["_field"] == "level" or r["_field"] == "longitude")
|> last()
|> drop(columns: ["_start", "_stop", "_measurement"])
This obviously don’t deliver the correct result as it only show the last recorded in the DB.
I were advise to maybe change the structure of my DB, to something like.
I need advise on the best structure for the DB and the query.
Thank you
