I’m currently working on a project to generate client data. This client data is connected to a raw influxdb bucket. I initially had the idea to use tasking and notebooks to perform a data analysis, and grafana for the dashboarding. However with the new influxdb 3 coming out the functionalities aren’t there any more. Do any of you have suggestions regarding this topic ?
Hello @nowy,
Yes! Sorry for the delay. I recommend using the Python Client and using something like Fargate or lambda to run your script.
Alternatively you could also use Quix or Mage.ai:
You can continue to use Grafana though for dashboarding
You can also use tableau or apache superset
In general I recommend using this org as a resource:
