From telegraf snmp to influxdb for a percentil95th graph line
Resume: How can I draw a continuous line when I have a table with one value for X time range?
I’m getting data from SNMP counters with input plugin with Telegraf.
Then I send to a bucket on InfluxDBv2.
All fine, I achieve a rate graph for the consumed bandwidth per minute. With a dynamic range, (30m 1h, 20h, 5d)
I’m trying to obtain quantile 0.95 from that graph. This must be a continuous line. So I will have two lines in the same graph.
The percentile line will be the percentile from that window.
Currently, I can see the perc95 value when I select view raw data, but unable to show this continuous line to the graph:
query 1:
import ""
experimental/aggregate"
    from(bucket: "g")
      |> filter(fn: (r) => r["_measurement"] == "_sapBaseStatsIngressPchipOfferedHiPrioOctets")
      |> filter(fn: (r) => r["description"] == "xxx: xxx")
      |> aggregateWindow(every: 1m, fn: last, createEmpty: false)
      |> aggregate.rate(every: 1m, unit: 1s)
      |> yield(name: "last")
Apparently fine, the problem starts here:
query2:
import "experimental/aggregate"
from(bucket: "g")
  |> quantile(q:0.95,)
A sample of csv output:
 false   false   true   true   false
 #datatype   string   long dateTime:RFC3339   dateTime:RFC3339   double
 #default    _result
                   result   table   _start   _stop   _value
                                 0       2021-04-15T09:40:36.360235132Z  2021-04-15T10:40:36.360235132Z
 532820.0516666668
Do you have any advice?
Hello @gil-obradors,
I did the following:
data = from(bucket: "telegraf")
  |> filter(fn: (r) => r["_measurement"] == "cpu")
  |> filter(fn: (r) => r["_field"] == "usage_system")
  |> filter(fn: (r) => r["cpu"] == "cpu-total")
  |> limit(n: 10)
data
  |> yield(name: "data")
r0 = data
  |> quantile(column: "_value", q: 0.95, method: "estimate_tdigest", compression: 1000.0)
  |> findRecord(fn: (key) => key.cpu == "cpu-total", idx: 0)
data
  |> map(fn: (r) => ({ r with _value: r0._value }))
  |> yield(name: "quant_line")
Does that work for your purposes?
Nice example,
could you pls say is my example correct: I want graph with only data that in (or below of line) quantile (drop the data above the line)?
And if I collect “cpu-total” not from 1 host, but from many (near 200) how to show this percentile line & percentile data for each host?
r0 = data
|> quantile(column: “_value”, q: 0.9, method: “estimate_tdigest”, compression: 1000.0)
|> findRecord(fn: (key) => key.cpu == “cpu-total”, idx: 0)
data
|> filter(fn: (r) => r[“_value”] < r0._value )
|> yield(name: “below_quant_line”)
data
|> yield(name: “quant_line”)
