Today, Influxdb 2.05 was upgraded in my dockers and it does not work anymore.
please find hereunder my configuration and traces
1: Client:
Version: 20.10.2
API version: 1.41
Go version: go1.13.8
Git commit: 20.10.2-0ubuntu1~20.10.1
Built: Tue Mar 23 23:21:32 2021
OS/Arch: linux/amd64
2: migration from Influxdb 1.8 to 2.0 works without issue
3: start docker-compose with Influxdb version 2.05.
docker starts but crashes at the end.
With previous version, it was working. I cannot revert to previous versions as previous tags don’t exist in th github
Traces :
2021-04-28T09:44:52.486291000Z 2021-04-28T09:44:52.484797214Z info booting influxd server in the background {“system”: “docker”}
2021-04-28T09:44:54.491720000Z 2021-04-28T09:44:54.490864600Z info pinging influxd… {“system”: “docker”}
2021-04-28T09:44:56.530532000Z 2021-04-28T09:44:56.529661141Z info pinging influxd… {“system”: “docker”}
2021-04-28T09:44:58.574439000Z 2021-04-28T09:44:58.573581995Z info pinging influxd… {“system”: “docker”}
2021-04-28T09:45:00.611272000Z 2021-04-28T09:45:00.610462985Z info pinging influxd… {“system”: “docker”}
2021-04-28T09:45:02.643694000Z 2021-04-28T09:45:02.642926910Z info pinging influxd… {“system”: “docker”}
2021-04-28T09:45:04.674626000Z 2021-04-28T09:45:04.673950932Z info pinging influxd… {“system”: “docker”}
2021-04-28T09:45:06.708452000Z 2021-04-28T09:45:06.707758675Z info pinging influxd… {“system”: “docker”}
2021-04-28T09:45:08.744978000Z 2021-04-28T09:45:08.744181216Z info pinging influxd… {“system”: “docker”}
2021-04-28T09:45:10.780972000Z 2021-04-28T09:45:10.780291546Z info pinging influxd… {“system”: “docker”}
2021-04-28T09:45:11.105450000Z ts=2021-04-28T09:45:11.105038Z lvl=info msg=“Welcome to InfluxDB” log_id=0TmyjWl0000 version=2.0.5 commit=741389781e build_date=2021-04-27T17:57:07Z
2021-04-28T09:45:11.115838000Z ts=2021-04-28T09:45:11.115366Z lvl=info msg=“Resources opened” log_id=0TmyjWl0000 service=bolt path=/var/lib/influxdb2/influxd.bolt
2021-04-28T09:45:11.118845000Z ts=2021-04-28T09:45:11.117971Z lvl=info msg=“Bringing up metadata migrations” log_id=0TmyjWl0000 service=migrations migration_count=15
2021-04-28T09:45:11.293618000Z ts=2021-04-28T09:45:11.292942Z lvl=info msg=“Using data dir” log_id=0TmyjWl0000 service=storage-engine service=store path=/var/lib/influxdb2/engine/data
2021-04-28T09:45:11.294331000Z ts=2021-04-28T09:45:11.293225Z lvl=info msg=“Compaction settings” log_id=0TmyjWl0000 service=storage-engine service=store max_concurrent_compactions=2 throughput_bytes_per_second=50331648 throughput_bytes_per_second_burst=50331648
2021-04-28T09:45:11.294845000Z ts=2021-04-28T09:45:11.293265Z lvl=info msg=“Open store (start)” log_id=0TmyjWl0000 service=storage-engine service=store op_name=tsdb_open op_event=start
2021-04-28T09:45:11.295780000Z ts=2021-04-28T09:45:11.293470Z lvl=info msg=“Open store (end)” log_id=0TmyjWl0000 service=storage-engine service=store op_name=tsdb_open op_event=end op_elapsed=0.154ms
2021-04-28T09:45:11.296378000Z ts=2021-04-28T09:45:11.293597Z lvl=info msg=“Starting retention policy enforcement service” log_id=0TmyjWl0000 service=retention check_interval=30m
2021-04-28T09:45:11.297003000Z ts=2021-04-28T09:45:11.293659Z lvl=info msg=“Starting precreation service” log_id=0TmyjWl0000 service=shard-precreation check_interval=10m advance_period=30m
2021-04-28T09:45:11.297724000Z ts=2021-04-28T09:45:11.293786Z lvl=error msg=“Failed to create query controller” log_id=0TmyjWl0000 error=“invalid controller config: QueueSize must be positive when ConcurrencyQuota is limited”
2021-04-28T09:45:11.298211000Z Error: invalid controller config: QueueSize must be positive when ConcurrencyQuota is limited
2021-04-28T09:45:11.298790000Z See ‘influxd -h’ for help
2021-04-28T09:45:12.816054000Z 2021-04-28T09:45:12.814751323Z info pinging influxd… {“system”: “docker”}
2021-04-28T09:45:14.850971000Z 2021-04-28T09:45:14.850219098Z info pinging influxd… {“system”: “docker”}
2021-04-28T09:45:16.890075000Z 2021-04-28T09:45:16.888846989Z info pinging influxd… {“system”: “docker”}
2021-04-28T09:45:18.932790000Z 2021-04-28T09:45:18.931792214Z info pinging influxd… {“system”: “docker”}
2021-04-28T09:45:20.971827000Z 2021-04-28T09:45:20.970406268Z info pinging influxd… {“system”: “docker”}
2021-04-28T09:45:23.013285000Z 2021-04-28T09:45:23.012397221Z info pinging influxd… {“system”: “docker”}
2021-04-28T09:45:25.052645000Z 2021-04-28T09:45:25.051484741Z info pinging influxd… {“system”: “docker”}
2021-04-28T09:45:27.095480000Z 2021-04-28T09:45:27.094203460Z info pinging influxd… {“system”: “docker”}
2021-04-28T09:45:29.132464000Z 2021-04-28T09:45:29.131309608Z info pinging influxd… {“system”: “docker”}
2021-04-28T09:45:31.175144000Z 2021-04-28T09:45:31.173861892Z info pinging influxd… {“system”: “docker”}
2021-04-28T09:45:33.214224000Z 2021-04-28T09:45:33.212745990Z info pinging influxd… {“system”: “docker”}
2021-04-28T09:45:35.254611000Z 2021-04-28T09:45:35.252773873Z info pinging influxd… {“system”: “docker”}
2021-04-28T09:45:37.291473000Z 2021-04-28T09:45:37.290389015Z info pinging influxd… {“system”: “docker”}
2021-04-28T09:45:39.329964000Z 2021-04-28T09:45:39.328627715Z info pinging influxd… {“system”: “docker”}
2021-04-28T09:45:41.372527000Z 2021-04-28T09:45:41.370999753Z info pinging influxd… {“system”: “docker”}
2021-04-28T09:45:43.413176000Z 2021-04-28T09:45:43.412085351Z info pinging influxd… {“system”: “docker”}
2021-04-28T09:45:45.456273000Z 2021-04-28T09:45:45.454921675Z info pinging influxd… {“system”: “docker”}
2021-04-28T09:45:47.495101000Z 2021-04-28T09:45:47.494000937Z info pinging influxd… {“system”: “docker”}
2021-04-28T09:45:49.535571000Z 2021-04-28T09:45:49.534357728Z info pinging influxd… {“system”: “docker”}
2021-04-28T09:45:51.575446000Z 2021-04-28T09:45:51.574366564Z info pinging influxd… {“system”: “docker”}
2021-04-28T09:45:53.619755000Z 2021-04-28T09:45:53.618536926Z info pinging influxd… {“system”: “docker”}
2021-04-28T09:45:53.655118000Z 2021-04-28T09:45:53.654349598Z error failed to detect influxd startup {“system”: “docker”, “ping_attempts”: “30”}
2021-04-28T09:45:53.659258000Z 2021-04-28T09:45:53.657646478Z warn cleaning bolt and engine files to prevent conflicts on retry {“system”: “docker”, “bolt_path”: “/var/lib/influxdb2/influxd.bolt”, “engine_path”: “/var/lib/influxdb2/engine”}
Edit: issue fixed thanks to Influxdb dev team
in config.toml, change line:
query-concurrency = 10 to query-concurrency = 0
