I check the config of website
and i see this
[fluxtask]
enabled = true
task-run-influxdb = "default"
task-run-bucket = "kapacitor_fluxtask_logs"
task-run-org = ""
task-run-orgid = ""
task-run-measurement = "runs"
task-run-influxdb : Name of the InfluxDB configuration in your
kapacitor.confto use to store Flux task data. To disable Flux task logging, set to"none".
this point what need to used? my config in kapacitor.conf in influxdb is:
[[influxdb]]
default = true
disable-subscriptions = true
enabled = true
http-port = 0
insecure-skip-verify = true
kapacitor-hostname = "xxxx"
name = "name_db"
password = "xxxx"
ssl-ca = ""
ssl-cert = ""
ssl-key = ""
startup-timeout = "5m0s"
subscription-mode = "cluster"
subscription-protocol = "http"
subscriptions-sync-interval = "1m0s"
timeout = "0s"
udp-bind = ""
udp-buffer = 1000
udp-read-buffer = 0
urls = ["http://xxxx:8086"]
username = "xxxx"
and taskflux it:
[fluxtask]
enabled = true
task-run-influxdb = "name_db"
task-run-org = "xxxx"
token = "xxxxx"
or what need config? i have this error in kapacitor
lvl=info msg="Error reading from bucket for task analytic storage, attempting to create it" service=fluxtask-analytical-store error="unauthorized access"
lvl=info msg="InfluxDB instance for analytic store not processing flux queries" service=fluxtask-analytical-store error="unauthorized access" errorVerbose
