I am writing a FluxQL query in Grafana v7.4.0 against InfluxDB v1.8.4.
Please first consider the following query snippet where I calculate the sum of differences across a set of tables (note that group() is used to combine all of the resultant tables into 1 table before computing the sum of all rows).
If I yield the result in a Grafana table, this results in a single ‘_value’ with an integer value. What I would like to do now is find a way to refer to the scalar value for this sum and use it in another query. I’ve tried using the following functions but they haven’t worked for me:
findRecord like this:
|> findRecord(idx: 0, fn: (key) => true)
Result: “500 Internal Server Error: type error 25:6-25:16: undefined identifier “findRecord””
getRecord like this:
|> getRecord(idx: 0)
Result: “500 Internal Server Error: type error 27:6-27:23: missing object properties (schema)”
getColumn like this:
|> getColumn(column: “_value”)
“500 Internal Server Error: type error 29:6-29:33: missing object properties (schema)”
I don’t think I have to use tableFind() because I only have 1 table in my output, right? I have tried using tableFind anyway and the result is the following error:
“500 Internal Server Error: type error 30:6-30:27: missing object properties (schema)”
If I just try to use the value as sum_of_diffs._value to refer to the result in another query then my influx query runs forever and doesn’t return anything.
I think I’m missing something basic. I tried adding this block after my sum() statement above:
r0 = sum_of_diffs
|> tableFind(fn: (key) => key._field == “_value”)
|> getRecord(idx: 0)
// Use record values
x = r0._value
The result is: "message:“500 Internal Server Error: error calling function “getRecord”: error calling function “tableFind”: no table found”.
I suspect this makes sense because I think key._field == “_value” might not be quite right. However, I’m not sure what to use for key._field because all I have left from my original query is one column called “_value” so I’m not sure what the group key would be for this table? Is it even a table?
