I am using flux to sum 5 minute data per day for the past 7 days. I use aggregateWindow on 2 columns and then union to join them back together. I use sort and fill to get the data on each time stamp together. This bit works fine. The issue I have is that the original table is still there.
Code
data = from(bucket: "home")
|> range(start: -7d)
|> filter(fn: (r) => r["_field"] == "BATTERY_CHARGE" or r["_field"] == "BATTERY_DISCHARGE")
|> map(fn: (r) => ({r with "Battery_Discharge": r.BATTERY_DISCHARGE / 12.0}))
|> map(fn: (r) => ({r with "Battery_Charge": r.BATTERY_CHARGE / 12.0}))
|> keep(columns: ["_time", "Battery_Charge", "Battery_Discharge"])
Discharge_Sum = data
|> aggregateWindow(column: "Battery_Discharge", every: 1d, offset: -8h, fn: sum)
Charge_Sum = data
|> aggregateWindow(column: "Battery_Charge", every: 1d, offset: -8h, fn: sum)
union(tables: [Discharge_Sum, Charge_Sum])
|> yield(name: "result")
|> group(columns: ["_time"], mode: "by")
|> sort(columns: ["Battery_Charge"])
|> fill(column: "Battery_Discharge", usePrevious: true)
|> tail(n: 1)
|> group()
|> tail(n: 7)
|> drop(fn: (column) => column =~ /^(_start|_stop|_measurement|location|region)/)
|> rename(columns: {Battery_Discharge: "Battery Discharge", Battery_Charge: "Battery Charge"})
The table data is as follows.
The bottom table is what I want to keep.
I have been unable to find anything that allows a table to be deleted. I have tried to filter out the first table value but after the union the filter functions only work on the output table.
any ideas?
