I’m using influx OSS 1.8 on windows to try out the new flux language, so we can port our client application from InfluxQL to Flux
I experimented a bit with it and start to develop an understanding on how it works, but i have a problem: it does not seem to return all data compared to InfluxQL
This is my data
metrics,device=toaster heat=0,energy=1 1588179706000000000
metrics,device=toaster heat=5,energy=3 1588179707000000000
metrics,device=toaster heat=500,energy=40 1588179708000000000
metrics,device=oven heat=0,energy=1 1588179706000000000
metrics,device=oven heat=100,energy=10 1588179707000000000
metrics,device=oven heat=200,energy=20 1588179708000000000
I put it directly into influxdb using curl
When i query it using influxql with a simple
SELECT * FROM metrics
I get all of it back
however, if i’m using flux
from(bucket:“fluxtest”)
|> range(start:0)
it only ever returns values with the device toaster, oven is nowhere to be found
When i add file(fn: ® => r.device == “oven”), the result is completely empty (which is somehwat to be expected when it’s not even there unfiltered)
I execute my queries using
curl -sS -XPOST localhost:8086/api/v2/query?epoch=ns -H “Accept:text/csv” -H “Content-type:application/vnd.flux” -d @fluxquery.txt
Am i missing something obvious?
I already tried the flux documentation with the keys() and column() function, but i only ever see toaster, never the oven
