Flux query: _field has slash in name, cannot get value
I am wondering how I can get the value out of a _field which has slashes in his name, ie:
r._field == “status_information/last_state_change/days”
my query looks like the following and I want to calculate a new column based on days * 86400 + hours * 3600, etc to get the number of seconds and graph it. As you may notice, I am not able to get the value out of >> r.status_information/last_state_change/days
Any Ideas? I am hunting cisco telemetry data, bfdsessionuptime…
Thanks in advance, best regards, Tom
from(bucket: "telemetry")
  |> range(start: -5m)
  |> filter(fn: (r) => r._measurement == "Cisco-IOS-XR-ip-bfd-oper:bfd/session-details/session-detail")
  |> filter(fn: (r) => r.destination_address =="192.168.1.3")
  |> filter(fn: (r) => (
          r._field == "status_information/last_state_change/days" or
          r._field == "status_information/last_state_change/hours"
  |> map(fn: (r) => ({ r with
      uptimeseconds: float(v: r.status_information/last_state_change/days * 86400.0) + float(v:
      r.status_information/last_state_change/hours * 3600.0)
@ToWo You can’t use dot notation if there are special characters or white space characters in your column name. You need to use bracket notation:
  |> range(start: -5m)
  |> filter(fn: (r) => (
      uptimeseconds: float(v: r["status_information/last_state_change/days"] * 86400.0) + float(v: r["status_information/last_state_change/hours"] * 3600.0)
@scott exactly what I was looking for, have had looked in to the samples for hours and the beginners guide fits best. thank you. Please allow one more question on this, I want to extend the filter r.destination_ipaddress == “192.168.xx” to a variable which than can be chosen at runtime from an ip-list ( ip address values to choose can be picked up by a distinct query to the destination_address). How would one start?
thanks in advance,
best regards,
Tom
@ToWo If you’re using InfluxDB Cloud or InfluxDB OSS 2.0, you can create a custom dashboard variable that lists all of the potential IPs.
The InfluxDB stores all dashboard variables in a v record that get’s append to all dashboard cells, so to use a variable in a dashboard query, you just use the v.variableName (or v["Variable Name"]) syntax:
  |> range(start: -5m)
  |> filter(fn: (r) => r.destination_address == v.IP)
  |> filter(fn: (r) => (
@scott Perfect! Thank you very much for this, now it fits all together,
cheers,
Tom
@ToWo No problem. Happy to help!
Hello Scott ,
I have the below query but seems i dont take any percentage value.
from(bucket: “telegraf”)
|> filter(fn: (r) => r[“_measurement”] == “Cisco-IOS-XR-ip-daps-oper:address-pool-service/nodes/node/vrfs/vrf/ipv4”)
|> filter(fn: (r) => r[“_field”] == “pools/pool_name” or r[“_field”] == “pools/free” or r[“_field”] == “pools/used” or r[“_field”] == “pools/total”)
|> filter(fn: (r) => r[“source”] == “CR-BNG-01”)
|> filter(fn: (r) => r[“vrf_name”] == “GREEN”)
|> filter(fn: (r) => r[“pools/pool_name”] == “EAD20_GREEN” or r[“pools/pool_name”] == “EAD21_GREEN”)
|> aggregateWindow(every: v.windowPeriod, fn: last, createEmpty: false)
|> map(
    fn: (r) => ({
        r with \_value: float(v: r\["pools/free"\]  / float(v: r\["pools/total"\] ) \* 100.0)
|> yield(name: “last”)
|> pivot(rowKey:[“_time”], columnKey: [“_field”], valueColumn: “_value”)
Thank you in advance for your help,
Minas
@Minas_Balaskas You need to pivot the data before you try to operate on multiple fields in map():
from(bucket: "telegraf")
    |> filter(fn: (r) => r["_measurement"] == "Cisco-IOS-XR-ip-daps-oper:address-pool-service/nodes/node/vrfs/vrf/ipv4")
    |> filter(fn: (r) => r["_field"] == "pools/pool_name" or r["_field"] == "pools/free" or r["_field"] == "pools/used" or r["_field"] == "pools/total")
    |> filter(fn: (r) => r["source"] == "CR-BNG-01")
    |> filter(fn: (r) => r["vrf_name"] == "GREEN")
    |> filter(fn: (r) => r["pools/pool_name"] == "EAD20_GREEN" or r["pools/pool_name"] == "EAD21_GREEN")
    |> map(
        fn: (r) => ({
            r with _value: float(v: r["pools/free"] / float(v: r["pools/total"] ) * 100.0)
    |> yield(name: "last")
Thank you Scott , Yes i corrected that part and everything works fine !!
Thanks for your help!!
