I’m joining a SQL table with an InfluxDB time series. Apart from the join operation, I would like to do the merge based on the timestamp: the one in the timeseries (_time) should be included in the boundaries contained in the SQL table (let’s say the SQL columns start and end) .
In practice, I would like to obtain something like (in SQL)
SELECT *
FROM sql_table s, timeseries ts
WHERE s.id = ts.id AND ts._time >= s.start AND ts._time >= s.end
Is it possible to do that? I’m able to do the join between the two tables using the join() operator in flux but I was wondering what is the equivalent of the WHERE condition in the example.
Any help? Thanks
