@MikeSPROW In your example, your using the existence of n_cpus data to determine that a host is online. I assume that if a host is offline, it won’t report any data. Unless you have a fixed list or number of total hosts, there isn’t a way to tell if any are offline.
It’s possible to detect if a host was online, but is now offline using monitor.deadman. But I don’t know if this is exactly what you’re trying to do.
Thanks is a big part of what i want to do but can i do this for all my bucket and/or org ? or i have to create à check for all my bucket ? I don’t know if in flux we can do some loops .
You can only query a single bucket in a from() call, but you could join results from two buckets in a single query. You’d probably need a task for each bucket.
I want to create a dashboard with a single stat for the count of online host and one for the offline host. I can’t do a for loop so i have to create a task for all my bucket ?
