hi,
I’m new to kapacitor but i think it can handle my use case:
i have incoming data where devices reports their state in a field: zero or one and have a tag called ID.
i want to filter out quick state changes AKA if i get a one for the given device but i had a zero 30s ago then i want to skip that value
i wrote this script:
dbrp "main"."autogen"
var zero = 30//s
var one = 30//s
stream
|from()
.measurement('Devices')
|elapsed('State',1s)
|where(lambda: ("elapsed" > one AND "State" == 1) OR ("elapsed" > zero AND "State" == 0))
|influxDBOut()
.database('main')
.measurement('Devices-filtered')
why elapsed clears all fields and tags?
can you recommend an alternative?
Thanks!
