i am bit new to telegraf. till now i used it mostly for collecting system metrics.
currently i am facing following problem: from several resources/devices i am collecting measurements in form of JSON data. these data are produced by sensors and send as JSON documents over mqtt protocol like this:
because those data are generated by students, i need to validate them - best way is with json schema. so what i need ideally is:
to write own validator in python (there will be more different measurements and related JSON documents)
if such JSON document fails the validation, it will be not passed further
if the input document is valid, i would like to convert it to influx line protocol by my own (the result will be composition of mqtt topic and mqtt message) and with output plugin i will write it to influxdb.
so the flow looks like:
inputs:mqtt_consumer → my python validator → outputs:influxdb_v2
is it possible to do something like this with telegraf or do i need to write my own script? and what is it then? is it input plugin? processor? can you point me, how to do that?
Hello @bletvaska,
Yes absolutely. You can use the execd processor plugin to do that.
Here’s an example repo:
# A simple processor. It reads stdin and writes it to stdout.
import sys
def main():
for line in sys.stdin:
print(line.rstrip())
sys.stdout.flush()
if __name__ == '__main__':
main()
