Hi everybody,
I got real time data from over 50 sensors per second. And for some difficult reasons, I can not filter the spike errors from those sensors’ side so I want to filter it out at one when the sensors’ data arrive Influxdb.
The filter would be simple that ( * > mean( * ) + stddev( * )) with * is all the data points. However, the problem is that I can not filter it out in Kapacitor . I can not use IF or CASE , or just some simple comparison like > , < in SELECT clause . And in WHERE clause, I can not use * there to filter data . Finally is the TICK script, I can not find any For Loop or While Loop to compare the each data point with the range to filter the spike errors out. It’s over 50 column so I can not go 1 by 1, I need to filer it all at 1 , for example in 30s interval.
May be I miss something or there is some other way to do it. So if anybody has any ideas about how to do this, please let me know !
Thank you in advances !
