I am currently trying to use a TICKscript to measure three values and compare them. They are all sampled at different intervals, one is sampled every 5 minutes and the other two every 30 minutes, but can also be sampled at random if viewed. I am not getting any alerts even though I should have quite a few. I have tried it with and without the stateDuration node. Here is the script:
var db = ‘edgex’
var rp = ‘autogen’
var measurement = ‘rtu’
var groupBy = [‘device’]
var whereSpaceTempFilter = lambda: (“resource_name” == ‘SpaceTemp’) AND isPresent(“value”)
var whereCoolingSPFilter = lambda: (“resource_name” == ‘EffCoolingSPT’) AND isPresent(“value”)
var queryTemp = ‘’‘SELECT mean(“value”) as “spaceTemp” FROM “edgex”.“autogen”.rtu WHERE (“resource_name” = ‘SpaceTemp’)’’’
var queryCoolSP = ‘’‘SELECT mean(“value”) as “effCoolingSP” FROM “edgex”.“autogen”.rtu WHERE (“resource_name” = ‘EffCoolingSPT’)’’’
var queryHeatSP = ‘’‘SELECT mean(“value”) as “effHeatingSP” FROM “edgex”.“autogen”.rtu WHERE (“resource_name” = ‘EffHeatingSPT’)’’’
var name = ‘Space Temp Batch Rule’
var idVar = name + ‘-{{.Group}}’
var message = ’ {{.ID}} {{.Name}} {{.TaskName}} {{.Group}} {{.Tags}} {{ index .Tags “value” }} {{.Level}} {{.Fields}} {{ index .Fields “value” }} {{.Time}}’
var idTag = ‘alertID’
var levelTag = ‘level’
var messageField = ‘message’
var durationField = ‘duration’
var outputDB = ‘chronograf’
var outputRP = ‘autogen’
var outputMeasurement = ‘alerts’
var triggerType = ‘threshold’
var spaceTemp = batch
|query(queryTemp)
.period(15m)
.every(2m)
.groupBy(time(20m), ‘device’)
.align()
.fill(‘previous’)
var effCoolingSPT = batch
|query(queryCoolSP)
.period(1h)
.every(2m)
.groupBy(time(2h), ‘device’)
.align()
.fill(‘previous’)
var effHeatingSPT = batch
|query(queryHeatSP)
.period(1h)
.every(2m)
.align()
.fill(‘previous’)
var joined = spaceTemp
|join(effCoolingSPT, effHeatingSPT)
.as(‘m1’, ‘m2’, ‘m3’)
.tolerance(1h)
var trigger = joined
|stateDuration(lambda: “m1.spaceTemp” > “m2.effCoolingSP” OR “m1.spaceTemp” < “m3.effHeatingSP”)
.unit(1m)
|alert()
.crit(lambda: “state_duration” > 4)
.message(message)
.id(idVar)
.idTag(idTag)
.levelTag(levelTag)
.messageField(messageField)
.durationField(durationField)
.log(’/tmp/alerts.log’)
trigger
|eval(lambda: float(“m1.spaceTemp”))
.as(‘spaceTemp’)
.keep()
|eval(lambda: float(“m2.effCoolingSP”))
.as(‘effCoolingSP’)
.keep()
|influxDBOut()
.create()
.database(outputDB)
.retentionPolicy(outputRP)
.tag(‘alertName’, name)
.tag(‘triggerType’, triggerType)
trigger
|httpOut(‘output’)
Unsure of what I am doing wrong.
