Hi
I have a deadman alert where I group the alerts by a “serial” code.
var data = stream
|from()
.database('mydb')
.retentionPolicy('autogen')
.measurement('measurement')
.groupBy(['serial'])
.where(lambda: TRUE)
var trigger = data
|deadman(0.0, 10m)
.stateChangesOnly()
.message('DEADMAN')
.details('')
.id('{{ index .Tags "sensorId" }}')
.idTag('alertID')
.levelTag('level')
.post('https://some.url')
trigger
|httpOut('output')
This works fine, however…I would like to not have it alert when I stop receiving measurements as a whole. Currently, if no measurements come through, it will send the alert but with “nil” values. I would like it to only send when the group itself doesn’t have any measurements coming through (usually when I just create the alert and it doesn’t have any memory yet). Is there a way to modify the query to filter out the “global” use case?
