Good morning,
I am using InfluxDB to ingest equipment data via API, formatted as line protocol.
While setting up and sending to the _Test bucket, a particular field, EngFuelRate.gph was ingested for a certain piece of equipment and available for query with no issue. After switching to the _Prod bucket, EngFuelRate.gph is no longer appearing as a field available for query.
All other pieces of equipment still have the field available in _Prod (although it appears that some have dropped other fields, such as IP, so this is a more widespread issue that just this one piece of equipment). Even weirder is that all payloads with the EngFuelRate.gph line protocol are successfuly ingested, so it’s not a formatting issue. Weirdest still is that if I send the same payload to _Test, it is received (204 response) and the new EngFuelRate.gph data points are available for display.
Even sending line protocl with just EngFuelRate.gph for this piece of equipment to _Prod is successfully received (204 response), but the field never appears.
Any thoughts are appreciated. Thanks.
