Influxdb is going down every 5 minutes due to this error.
What is the problem here and how it can be solved ?
It displays this error in the logs, and then a stacktrace is given.
This is the stacktrace below,
runtime stack:
runtime.throw(0xac3afa, 0x16) /usr/local/go/src/runtime/panic.go:566 +0x95
runtime.sysMap(0xc44e8a0000, 0x100000, 0x455600, 0xe7b938) /usr/local/go/src/runtime/mem_linux.go:219 +0x1d0
runtime.(*mheap).sysAlloc(0xe623a0, 0x100000, 0xc0000ba278) /usr/local/go/src/runtime/malloc.go:407 +0x37a
runtime.(*mheap).grow(0xe623a0, 0x1, 0x0) /usr/local/go/src/runtime/mheap.go:726 +0x62runtime.(*mheap).allocSpanLocked(0xe623a0, 0x1, 0x75)
/usr/local/go/src/runtime/mheap.go:630 +0x4f2runtime.(*mheap).alloc_m(0xe623a0, 0x1, 0x10, 0xc44e895d5d)
/usr/local/go/src/runtime/mheap.go:515 +0xe0runtime.(*mheap).alloc.func1()
/usr/local/go/src/runtime/mheap.go:579 +0x4bruntime.systemstack(0x7f6b078e1d48)
/usr/local/go/src/runtime/asm_amd64.s:314 +0xabruntime.(*mheap).alloc(0xe623a0, 0x1, 0x10000000010, 0x410b79)
/usr/local/go/src/runtime/mheap.go:580 +0x73runtime.(*mcentral).grow(0xe63d70, 0x0)
/usr/local/go/src/runtime/mcentral.go:210 +0x94runtime.(*mcentral).cacheSpan(0xe63d70, 0xc420015228)
/usr/local/go/src/runtime/mcentral.go:91 +0xfaruntime.(*mcache).refill(0x7f6b2c9e1000, 0xc400000010, 0xc43a837940)
/usr/local/go/src/runtime/mcache.go:121 +0xaeruntime.(*mcache).nextFree.func1()
/usr/local/go/src/runtime/malloc.go:505 +0x33runtime.systemstack(0xc420014000)
/usr/local/go/src/runtime/asm_amd64.s:298 +0x79runtime.mstart()
/usr/local/go/src/runtime/proc.go:1079`
And below are many other go routines which I cannot paste here as they are too large.
