I’ve been attempting to insert data into InfluxDB Cloud Serverless via the web app’s File Upload > Upload a CSV functionality.
I am receiving an error “Failed to upload the selected CSV: error in csv.from(): failed to read metadata: default Table ID is not an integer” when uploading the following CSV data:
#group,FALSE,FALSE,FALSE,FALSE
#datatype,measurement,tag,double,dateTime:RFC3339
#default,weight,override,
measurement,source,qty,time
,144.6,2023-05-13T16:18:00Z
,143.2,2023-05-12T14:19:00Z
,143,2023-05-11T18:42:00Z
,141.7,2023-05-10T14:51:00Z
,140.2,2023-05-08T13:22:00Z
,142.1,2023-05-14T15:51:00Z
,142.1,2023-05-16T13:05:00Z
,143.9,2023-05-15T17:41:00Z
,142.1,2023-05-15T13:41:00Z
As best I can tell from reading the Annotated CSV documentation, this should work. I’m providing a table (measurement) name “weight” and getting an error about a missing integer Table ID.
Note that there is no data currently in the bucket for that measurement name, but I get the same error if I try to add the data to an existing measurement (table).
Any suggestions on how to get this to work would be greatly appreciated.
