Hey folks,
I’am quite new to influxDB and i am having difficulties with alerting.
I successfully implemented alerting based on thresholds.
So far so good. But I have no idea how to set my alerts up to get the extreme Values (on LevelReset)
What i want to do:
- Alert me imeedialely (no window) if a Value exceeds threshold [works already] (e.g level is below 49)
- i get noitified via pushover about the alert [works already] “Attention value is 48.85”
- I want to get notified if the alert cleared and the value is above 50 again [works already] “Value is good again 50.02”
- What i really want to know [dont know how to implement it]
“Value is good again 50.02 extreme Value was 45.88”
As you can see, i get alerted if the value exceeds the threshold, but i do not get the absolute extreme value of the anomaly.
Do you guys have any information for me on this topic?
var db = 'homeassistant'
var rp = 'autogen'
var measurement = 'Hz'
var groupBy = []
var whereFilter = lambda: ("entity_id" == 'frequency') AND isPresent("value")
var name = 'Frequenz crit'
var idVar = name
var message = ' {{.Level}} {{ index .Fields "value" }} {{.Time}}'
var idTag = 'alertID'
var levelTag = 'level'
var messageField = 'message'
var outputDB = 'chronograf'
var outputRP = 'autogen'
var outputMeasurement = 'alerts'
var triggerType = 'threshold'
var lcrit = 49.85
var ucrit = 50.15
var lwarn = 49.9
var uwarn = 50.1
var lok = 49.95
var uok = 50.05
var data = stream
|from()
.database(db)
.retentionPolicy(rp)
.measurement(measurement)
.groupBy(groupBy)
.where(whereFilter)
|eval(lambda: "value")
.as('value')
var trigger = data
|alert()
.crit(lambda: "value" < lcrit OR "value" > ucrit)
.critReset(lambda: "value" > lwarn AND "value" < uwarn)
.warn(lambda: "value" < lwarn OR "value" > uwarn)
.warnReset(lambda: "value" > lok AND "value" < uok)
.message(message)
.id(idVar)
.idTag(idTag)
.levelTag(levelTag)
.messageField(messageField)
.durationField(durationField)
.stateChangesOnly()
.pushover()
.device('xperiaz3')
.title('AbNormal Frequency ')
trigger
|eval(lambda: float("value"))
.as('value')
.keep()
|influxDBOut()
.create()
.database(outputDB)
.retentionPolicy(outputRP)
.tag('alertName', name)
trigger
|httpOut('output')
