I’m trying to display an overview of a large number of series and display the five top ones and group everything else as a single “Other” table.
I don’t think there is a way to do that in Flux but I figure I would ask here. If only there was a way to convert a table to an array, that would probably save the day.
I did manage to get the biggest objects with the following :
from(bucket: "spaceview")
|> filter(fn: (r) => r["_measurement"] == "volume")
|> filter(fn: (r) => r["_field"] == "used")
|> filter(fn: (r) => r["root"] == "false")
|> filter(fn: (r) => r["styleEx"] == "flexvol")
|> highestCurrent(n:5, groupColumns: ["volume"])
But I don’t see a way to use join or filter to use that to get the data for those volumes only, or every other volume only.
Well it seems I finally found the magic recipe, which seems to drop some column like _from
which break the enforced grouping on _from/_to
and makes for the expected join.
import "join"
import "join"
data = from(bucket: "spaceview")
|> drop(columns: ["_from"])
|> group(columns: ["volume"])
annotated = from(bucket: "spaceview")
|> set(key: "big", value: "true")
|> join.right(
right: data,
on: (l, r) => l.volume == r.volume,
as: (l, r) => ({r with big: l.big}),
annotated
|> filter(fn: (r) => not exists r["big"])
|> group(columns: ["_time"])
|> sum()
|> group()
|> set(key: "volume", value:"other")
|> yield(name: "other")
annotated
|> filter(fn: (r) => exists r["big"])
|> yield(name: "big")
And the final query with a different method :
import "join"
// Normalize time windows as each system report separately
|> aggregateWindow(every: 1d, fn: sum, createEmpty: false)
|> drop(columns: ["_start","_stop"])
|> group(columns: ["volume","vserver"])
|> sort(columns: ["_time"])
data
|> range(start: -2w, stop: v.timeRangeStop)
|> highestCurrent(n:5, groupColumns: ["volume","vserver"])
|> join.right(
right: data,
on: (l, r) => l.volume == r.volume and l.vserver == r.vserver,
// When "big" is not defined, set the volume name and server name as "other"
// for later sum()
|> map(fn: (r) => ({
r with
volume:
if not exists r.big then "other"
else r.volume,
vserver:
else r.vserver
|> group(columns: ["_time","volume","vserver"])
|> sum()
@ybizeul Thank you for sharing your solution!!
