Sample Code:
url = “http://localhost:9999/api/v2/write”
params = {‘org’:‘qwerty’, ‘bucket’:‘initial’}
data = {‘baby’,‘symbol’:‘test’,‘name’:‘test1’}
response = requests.request(“POST”, url, params=params, data=data, headers=headers1)
print(response.code)
data format not working with line protocol
Hello @gudivadakoti,
Thank you for your question. Can you please print the request?
Is curl successful?
curl "http://localhost:9999/api/v2/write?org=YOUR_ORG&bucket=YOUR_BUCKET&precision=s" \
--header "Authorization: Token YOURAUTHTOKEN" \
--data-raw "mem,host=host1 used_percent=23.43234543 1556896326"
Or maybe try the CLI to see if you can write data at all
./influx write @/pwd/lineprotocol.txt -o "Influx" -b "Anais" -t "<$your token>"
Have you had a chance to check out the documentation here ?
@Ana, Thanks for response. Curl is working fine.
But I try write using JSON data format via python requests module. It seems that not accepting data in JSON format.
hi @gudivadakoti you resolve that?
I fixed it by directly passing the string in Line Protocol to the data parameter on the requests.post
