I am trying to compute the modified z-score for anomaly detection purposes. When I try and take the median to compute the MAD (as shown in the image), I get the error
expected stream[A] but found (<-: stream[B]) => stream[{C with abs: D}] (function)
I am unsure of how to solve this error since median is working perfectly fine in median. It is failing on line 19, where we take the median of abs.
import "math"
data = from(bucket: "timeseries")
|> filter(fn: (r) => r["device"] == "XXXXXXXX")
|> keep(columns: ["_time", "_value", "_field"])
median = data
|> median()
|> map(fn: (r) => ({ r with median: r._value }))
|> keep(columns: ["median", "_field"])
abs = join(tables: {data: data, median: median}, on: ["_field"])
|> map(fn: (r) => ({ r with abs: math.abs(x: r._value - r.median) }))
|> keep(columns: ["_field", "abs"])
mad = abs
|> median() // CODE FAILS HERE: expected stream[A] but found (<-: stream[B]) => stream[{C with abs: D}] (function)
|> map(fn: (r) => ({ r with mad: r.abs }))
|> keep(columns: ["mad", "_field"])
modifiedZScore = join(tables: {data: data, mad: mad}, on: ["_field"])
|> map(fn: (r) => ({ r with modified_z_score: 0.6745 * (r._value - r.median) / r.mad }))
|> keep(columns: ["_time", "_value", "_field", "modified_z_score"])
|> yield()
Any help is greatly appreciated.
