devth
May 17, 2017, 4:46pm
1
I’m using the telegraf-ds chart 1.3 running on Kubernetes 1.6.2 (GKE) via the tick-charts repo.
Logs show continuous errors like:
2017-05-17T16:44:44Z E! Error in plugin [inputs.docker]: E! Error gathering container [/k8s_chronograf_chronograf-prod-chronograf-604308575-ldmn6_infra_8963a62f-3a53-11e7-9643-42010a8001a5_0] stats: Error getting docker stats: context deadline exceeded
The above is the log for the chronograf pod, but this error is logged for 18 out of my 45 pods.
I tried increasing the docker input timeout to 10s and then to 20s with the same result.
@devth I’ve seen this issue on every cluster I’ve spun up but it seems intermittent and slightly random as to which pods are affected. I initially thought this was isolated to the kube-system namespace but it appears it is not. Looking at the docker logs on the host the following errors are repeated:
May 17 02:06:02 gke-influx-kube-default-pool-1202464b-3g6m docker[1290]: time="2017-05-17T02:06:02.551558050Z" level=error msg="collecting stats for 5ac5af5db592267d33ea53d3f3eb53757bf
May 17 02:06:02 gke-influx-kube-default-pool-1202464b-3g6m docker[1290]: time="2017-05-17T02:06:02.556143500Z" level=error msg="collecting stats for fc54907131a326049c1e0e6ef498e31d426
May 17 02:06:02 gke-influx-kube-default-pool-1202464b-3g6m docker[1290]: time="2017-05-17T02:06:02.557884430Z" level=error msg="collecting stats for b4325f3fdf93ac516fa1b80bd62e4e1592e
May 17 02:06:02 gke-influx-kube-default-pool-1202464b-3g6m docker[1290]: time="2017-05-17T02:06:02.561983229Z" level=error msg="collecting stats for 86290e7ba07c3d146848a5795f6cdb4436a
May 17 02:06:02 gke-influx-kube-default-pool-1202464b-3g6m docker[1290]: time="2017-05-17T02:06:02.563776749Z" level=error msg="collecting stats for c51d92e5dcb0ec3f271e28f00c004b3bf02
May 17 02:06:02 gke-influx-kube-default-pool-1202464b-3g6m docker[1290]: time="2017-05-17T02:06:02.565495838Z" level=error msg="collecting stats for 8feadbb8ddacfc7fb37d99065c0e3c01632
Docker Version information on gke hosts:
Client:
Version: 1.11.2
API version: 1.23
Go version: go1.7.4
Git commit: 4dc5990
Built:
OS/Arch: linux/amd64
Server:
Version: 1.11.2
API version: 1.23
Go version: go1.7.4
Git commit: 4dc5990
Built:
and related docker issues:
opened 10:44AM - 19 Jan 17 UTC
area/kernel
area/networking
If you are reporting a new issue, make sure that we do not have any duplic… ates
already open. You can ensure this by searching the issue list for this
repository. If there is a duplicate, please close your issue and add a comment
to the existing issue instead.
If you suspect your issue is a bug, please edit your issue description to
include the BUG REPORT INFORMATION shown below. If you fail to provide this
information within 7 days, we cannot debug your issue and will close it. We
will, however, reopen it if you later provide the information.
For more information about reporting issues, see
https://github.com/docker/docker/blob/master/CONTRIBUTING.md#reporting-other-issues
GENERAL SUPPORT INFORMATION
The GitHub issue tracker is for bug reports and feature requests.
General support can be found at the following locations:
- Docker Support Forums - https://forums.docker.com
- IRC - irc.freenode.net #docker channel
- Post a question on StackOverflow, using the Docker tag
Use the commands below to provide key information from your environment:
You do NOT have to include this information if this is a FEATURE REQUEST
**Description**
It seems related to the option "live-restore": true,
When i restart docker daemon, containers are not restarted and then when i try a docker stats on one of my running conatiner, there is no metrics :
CONTAINER CPU % MEM USAGE / LIMIT MEM % NET I/O BLOCK I/O PIDS
infra_consul_static_1 -- -- / -- -- -- / -- -- / -- --
after restart of the container i got my metrics back:
infra_consul_static_1 0.00% 10.81 MiB / 3.86 GiB 0.27% 17.8 kB / 8.624 kB 7.401 MB / 16.38 kB 0
Briefly describe the problem you are having in a few paragraphs.
**Steps to reproduce the issue:**
1. add live-restore=on daemon.json
2. systemctl start docker
3. docker run --name httpd -d httpd && docker stats httpd => all is OK
4. systemctl restart docker
5. docker stats httpd => No data received
And on docker log, i can see
Got lots of lines like this one on 1.12.5 on centos7 (and 1.12.6) :
docker: time="2017-01-18T16:04:28.671968138+01:00" level=error msg="collecting stats for httpd: sandbox httpd not found"
opened 08:57PM - 05 Jan 17 UTC
area/networking
version/1.12
**Description**
Recently, docker was upgraded from Docker 1.12.2 to Docker 1.… 12.5 on a set of Centos 7.2 servers. The docker configuration includes live-restore and fixed-cidr. Two containers were running prior to upgrade.
After the upgrade, a new container was launched. Docker inspect shows the MAC and IP address given to the new container matches that of one of the containers that was started prior to the upgrade.
Potentially similar to: #10096
1. Start a container with fixed-cidr enabled. Capture the IP address and MAC from docker inspect.
2. Upgrade from 1.12.2 to 1.12.5
3. Start a new container and compare the IP address and MAC.
**Describe the results you received:**
The IP address and MAC address of the new container is the same as the container started prior to upgrade.
**Describe the results you expected:**
IP addresses should not be reused as it impacts existing containers.
**Additional information you deem important (e.g. issue happens only occasionally):**
The upgrade was performed via yum upgrade using the yum.dockerproject.org yum repo.
I have validated this behavior on 3 different nodes.
**Output of `docker version`:**
Client:
Version: 1.12.5
API version: 1.24
Go version: go1.6.4
Git commit: 7392c3b
Built: Fri Dec 16 02:23:59 2016
Server:
Version: 1.12.5
API version: 1.24
Go version: go1.6.4
Git commit: 7392c3b
**Output of `docker info`:**
Containers: 3
Running: 2
Paused: 0
Stopped: 1
Images: 29
Server Version: 1.12.5
Storage Driver: devicemapper
Pool Name: vg01-docker--pool
Pool Blocksize: 524.3 kB
Base Device Size: 268.4 GB
Backing Filesystem: xfs
Data file:
Metadata file:
Data Space Used: 39.92 GB
Data Space Total: 5.63 TB
Data Space Available: 5.59 TB
Metadata Space Used: 15.8 MB
Metadata Space Total: 16.98 GB
Metadata Space Available: 16.96 GB
Thin Pool Minimum Free Space: 563 GB
Udev Sync Supported: true
Deferred Removal Enabled: false
Deferred Deletion Enabled: false
Deferred Deleted Device Count: 0
Library Version: 1.02.107-RHEL7 (2015-12-01)
Logging Driver: json-file
Cgroup Driver: cgroupfs
Plugins:
Volume: local
Network: overlay null host bridge
Swarm: inactive
Runtimes: runc
Default Runtime: runc
Security Options: seccomp
Kernel Version: 3.10.0-327.13.1.el7.x86_64
Operating System: CentOS Linux 7 (Core)
OSType: linux
Architecture: x86_64
CPUs: 32
Total Memory: 251.6 GiB
Docker Root Dir: /docker
Debug Mode (client): false
Debug Mode (server): true
File Descriptors: 26
Goroutines: 31
System Time: 2017-01-05T20:54:45.674747462Z
EventsListeners: 0
Registry: https://index.docker.io/v1/
WARNING: bridge-nf-call-iptables is disabled
WARNING: bridge-nf-call-ip6tables is disabled
Insecure Registries:
127.0.0.0/8
**Additional environment details (AWS, VirtualBox, physical, etc.):**
Physical, CentOS 7.2
