Email notification with Sendgrid
I’m running into trouble creating an emal alert using sendgrid using the example from documentation
import "http"
// Import the Secrets package if you store your API key as a secret.
// For detail on how to do this, see Step 4 above.
// Retrieve the secret if applicable. Otherwise, skip this line
// and add the API key as the Bearer token in the Authorization header.
SENDGRID_APIKEY = secrets.get(key: "SENDGRID_APIKEY")
numberOfCrits = from(bucket: "_monitoring")
|> range(start: -task.every)
|> filter(fn: (r) => r.measurement == "statuses" and r.level == "crit")
|> count()
numberOfCrits
  |> map(fn: (r) => (if r._value > 3 then {
    r with _value: http.post(
      url: "https://api.sendgrid.com/v3/mail/send",
      headers: {"Content-Type": "application/json", Authorization: "Bearer ${SENDGRID_APIKEY}"},
      data: bytes(v: "{
    \"personalizations\": [{
      \"to\": [{
       \"email\": \”jane.doe@example.com\"}],
       \"subject\": \”InfluxData critical alert\"
      \"from\": {\"email\": \"john.doe@example.com\"},
      \"content\": [{
        \"type\": \"text/plain\",
         \"value\": \”Example alert text\"
    }\""))} else {r with _value: 0}))
I stored my sendcloud API key using the CLI for my organization.
Even if I change the email in the script above, when I’m trying to save the script I get the following error
Failed to create new task: invalid AST: loc 0:0-0:0: unknown operator "<INVALID_OP>
Any ideas?
Thanks!
Martin
@hermiot Are you running this as a task or just a normal query?
It looks like you have a mix of standard double-quotes and smart double-quotes (in front of jane here), that could be causing a problem.
Same in a few other places.
And also it looks like you have an extra \" at the end of your JSON that shouldn’t be there.
I just went through all the email examples in the docs, and most of them had syntax issues. I have a PR that fixes them. Try this:
import "http"
	|> count()
numberOfCrits
      headers: {
        "Authorization": "Bearer ${SENDGRID_APIKEY}"
      data: bytes(v: "{
            \"to\": [
                \"email\": \"jane.doe@example.com\"
        \"from\": {
        \"subject\": \"InfluxDB critical alert\",
        \"content\": [
            \"value\": \"There have been ${string(v: r._value)} critical statuses.\"
      }"))} else {r with _value: 0}))
Thank you very much for helping me. I thought it has something to do with the synthax but I’m just starting with flux.
Eveything is working now! :slight_smile:
Did anybody use sendgrid so far?
I dont get an error, when running the task but I don’t get an email also.
I changed the r._value > 3 to r._value >=1 so every crit alert should be reportet.
The API Key I’m using has full access and works when I test it via sendgrid API documentation website.
Thaks!
@hermiot Are you certain that you have critical statuses?
Yes, Slack is working fine. Also HTTP Post.
But I can’t get the task, using the example, running.
I don’t know if http.post() has any response error code handling. I’m wondering if there’s an error in the payload. Can you try a manual API call (outside of Flux) using the same request body to see if it returns an error?
I’m using Node-RED to send Emails which works fine.
It’s a workarround which is not nice but works for me.
