I’m trying to parse the following json data with Telegraf and InfluxDB (both latest docker images) - but I cannot get it to parse the values and the dates to get the correct output.
Here’s sample JSON data:
"MPRN": "123456",
"Meter Serial Number": "678910",
"Read Value": "0.305000",
"Read Type": "Active Import Interval (kW)",
"Read Date and End Time": "09-12-2023 03:30"
"MPRN": "123456",
"Read Value": "0.278000",
"Read Date and End Time": "09-12-2023 03:00"
"MPRN": "123456",
"Read Value": "0.336000",
"Read Date and End Time": "09-12-2023 02:30"
"MPRN": "10016256272",
"Meter Serial Number": "23125313",
"Read Value": "0.379000",
"Read Date and End Time": "09-12-2023 02:00"
here’s my Telegraf config:
# Parse a complete file each interval
[[inputs.file]]
files = ["/etc/telegraf/json_data.json"]
## Data format to consume.
## more about them here:
data_format = "json_v2"
[[inputs.file.json_v2]]
measurement_name = "Electricity_Usage" # A string that will become the new measurement name
timestamp_path = "@this.#.Read Date and End Time" # A string with valid GJSON path syntax to a valid timestamp (single value)
timestamp_format = "02-01-2006 15:04" # A string with a valid timestamp format (see below for possible values)
timestamp_timezone = "Europe/Dublin" # A string with with a valid timezone (see below for possible values)
[[inputs.file.json_v2.object]]
path = "@this.#" # A string with valid GJSON path syntax
[[inputs.file.json_v2.field]]
path = "@this.#.Read Value" # A string with valid GJSON path syntax
rename = "kW" # A string with a new name for the tag key
type = "float" # A string specifying the type (int,uint,float,string,bool)
[[outputs.file]]
## Files to write to, "stdout" is a specially handled file.
files = ["stdout"]
which outputs:
Electricity_Usage,host=XxX kW=0.602 1702242360000000000
Electricity_Usage,host=XxX kW=0.398 1702242360000000000
Electricity_Usage,host=XxX kW=0.464 1702242360000000000
Electricity_Usage,host=XxX kW=0.564 1702242360000000000
Electricity_Usage,host=XxX kW=0.754 1702242360000000000
Electricity_Usage,host=XxX kW=0.578 1702242360000000000
Electricity_Usage,host=XxX kW=0.683 1702242360000000000
Electricity_Usage,host=XxX kW=0.815 1702242360000000000
Electricity_Usage,host=XxX kW=0.671 1702242360000000000
Electricity_Usage,host=XxX kW=0.661 1702242360000000000
Electricity_Usage,host=XxX kW=0.74 1702242360000000000
Electricity_Usage,host=XxX kW=0.62 1702242360000000000
Electricity_Usage,host=XxX kW=0.868 1702242360000000000
Electricity_Usage,host=XxX kW=0.574 1702242360000000000
Electricity_Usage,host=XxX kW=0.378 1702242360000000000
Electricity_Usage,host=XxX kW=0.411 1702242360000000000
Electricity_Usage,host=XxX kW=0.562 1702242360000000000
Electricity_Usage,host=XxX kW=0.307 1702242360000000000
Electricity_Usage,host=XxX kW=0.344 1702242360000000000
Electricity_Usage,host=XxX kW=0.479 1702242360000000000
Electricity_Usage,host=XxX kW=0.511 1702242360000000000
So it looks like it’s parsing the kW correctly, but the timestamp is now which is incorrect. I’m also not sure if it’s enumerating both correctly - one kW value should be tied to one timestamp - some experimentation I did had them repeating (calling them fields?). I’m new to Telegraf/influxdb - so maybe it’s blindingly obvious and I just can’t see it. I have read up on GJSON and the new JSONv2 Telegraf parser a good bit, as well as looking through examples on GitHub and I can’t crack it yet.
Any help much appreciated !
