I am facing the same problem.
Here is my script:
import "date"
// from grafana v.defaultBucket
defaultBucket = "my_bucket"
// from grafana v.windowPeriod
reqPeriod = 5s
// from grafana template variable ${devices:regex}
devices = /some_measurement/
minPeriod = 5s
defaultPeriod = if uint(v: reqPeriod) < uint(v: minPeriod) then
minPeriod
else
reqPeriod
query_base = (bucket=defaultBucket, devices=/.*/, systems=/.*/, fields=/.*/, start=v.timeRangeStart, stop=v.timeRangeStop) =>
from(bucket: bucket)
|> range(start: start, stop: stop)
|> filter(fn: (r) =>
r._measurement =~ devices
and r.system =~ systems
and r._field =~ fields
query_timeseries = (bucket=defaultBucket, devices=/.*/, systems=/.*/, fields=/.*/, start=v.timeRangeStart, stop=v.timeRangeStop, period=defaultPeriod) =>
query_base(
bucket: bucket,
devices: devices,
systems: systems,
fields: fields,
start: start,
stop: stop
|> aggregateWindow(every: period, fn: mean)
qCommon = query_timeseries(devices: devices, systems: /(mppt|pd)/, fields: /(carOut|(usb|qcUsb|typec)\d+)Watts/)
|> map(fn: (r) => ({
_time: r._time,
// Resulting field
// since we use already use map because of 'carOutWatts', do it here
// it avoids a second call to map or rename
_field: "DC",
// This should be done prior to storing in the database, ignore for this problem
_value: if r._field == "carOutWatts" then r._value / 10.0 else r._value
a = () => qCommon
|> group(columns: ["_time","_field"])
|> sum()
|> group(columns: ["_field"])
b = () => qCommon
// Be sure to use:
// - timeSrc: "_start" (to avoid skewing the results by 1s)
// - createEmpty: false (to avoid creating empty values in our 5s original aggregate)
|> aggregateWindow(every: 1s, fn: sum, timeSrc: "_start", createEmpty: false)
//a()
b()
function b (using aggregateWindow) is way faster than a (group + sum + group), about 2 to 3 times faster.
The suggestion of using pivot prior to the calculation is not possible, since i don’t know the exact fields to sum (the \d in the regexp, i may have 3 usb, 4 typec, or maybe 5, or… who knows?)
It was my understanding that aggregateWindow was something like:
tables
|> window(...)
|> sum(...)
|> group(...)
Wich, at least in my mind, should actually be slower than
tables
|> group(...)
|> sum(...)
|> group(...)
Since window actually has to compare the time of every row of every table to group them together.
I hence have 3 questions:
- Is my assumption about the logic of
aggregateWindow wrong?
- If not, how can it be faster that the “group + sum + group” solution?
- Isn’t there a better, faster, way to do this? (while
aggregateWindow is faster, it is still quite slow on a large window)
