I have Node-Red and InfluxDB installed on Ubuntu:
Ubuntu 20.04.3 LTS
Node-RED 2.0.5
InfluxDB 1.8.9
node-red-contrib-influxdb 0.6.1
When I write data to the influxdb out node I get a ECONNREFUSED error after a number of successful writes.
If I write the data at a fixed frequency (eg every 5 seconds or every 2 seconds) then I get the error after every 21 writes.
If I write date with a random frequency then I get the error after a variable number of writes but I can’t see a relationship between the (random) frequency and the number of writes before I get an error.
The error message is: Error: connect ECONNREFUSED 127.0.0.1:8086
Does anyone have any idea what the problem might be?
Thanks.
In syslog I see the influxdb.service continuously restarting:
Aug 28 07:15:36 klomar-Inspiron-3668 influxd-systemd-start.sh[26638]: [httpd] 127.0.0.1 - admin [28/Aug/2021:07:15:36 +0100] "POST /write?db=sensors&p=%5BREDACTED%5D&precision=n&rp=&u=admin HTTP/1.1 " 204 0 "-" "-" 5bcb706e-07c7-11ec-801c-484d7eb95aef 3290
Aug 28 07:15:36 klomar-Inspiron-3668 influxd-systemd-start.sh[26638]: [httpd] 127.0.0.1 - admin [28/Aug/2021:07:15:36 +0100] "POST /write?db=sensors&p=%5BREDACTED%5D&precision=n&rp=&u=admin HTTP/1.1 " 204 0 "-" "-" 5bcc2958-07c7-11ec-801d-484d7eb95aef 3335
Aug 28 07:15:36 klomar-Inspiron-3668 influxd-systemd-start.sh[26638]: [httpd] 127.0.0.1 - - [28/Aug/2021:07:15:36 +0100] "GET /health HTTP/1.1" 401 55 "-" "curl/7.68.0" 5bce328f-07c7-11ec-801e-484d7eb95aef 51
Aug 28 07:15:36 klomar-Inspiron-3668 influxd-systemd-start.sh[26637]: Failed to reach influxdb http endpoint at http://localhost:8086/health
Aug 28 07:15:36 klomar-Inspiron-3668 systemd[1]: influxdb.service: Control process exited, code=exited, status=1/FAILURE
Aug 28 07:15:36 klomar-Inspiron-3668 influxd-systemd-start.sh[26638]: ts=2021-08-28T06:15:36.178114Z lvl=info msg="Signal received, initializing clean shutdown..." log_id=0WErDlNG000
Aug 28 07:15:36 klomar-Inspiron-3668 influxd-systemd-start.sh[26638]: ts=2021-08-28T06:15:36.178132Z lvl=info msg="Waiting for clean shutdown..." log_id=0WErDlNG000
Aug 28 07:15:36 klomar-Inspiron-3668 influxd-systemd-start.sh[26638]: [tcp] 2021/08/28 07:15:36 tcp.Mux: Listener at 127.0.0.1:8088 failed failed to accept a connection, closing all listeners - accept tcp 127.0.0.1:8088: use of closed network connection
Aug 28 07:15:36 klomar-Inspiron-3668 influxd-systemd-start.sh[26638]: ts=2021-08-28T06:15:36.178207Z lvl=info msg="Listener closed" log_id=0WErDlNG000 service=snapshot
Aug 28 07:15:36 klomar-Inspiron-3668 influxd-systemd-start.sh[26638]: ts=2021-08-28T06:15:36.178229Z lvl=info msg="Shutting down monitor service" log_id=0WErDlNG000 service=monitor
Aug 28 07:15:36 klomar-Inspiron-3668 influxd-systemd-start.sh[26638]: ts=2021-08-28T06:15:36.178239Z lvl=info msg="Terminating storage of statistics" log_id=0WErDlNG000 service=monitor
Aug 28 07:15:36 klomar-Inspiron-3668 influxd-systemd-start.sh[26638]: ts=2021-08-28T06:15:36.178254Z lvl=info msg="Terminating precreation service" log_id=0WErDlNG000 service=shard-precreation
Aug 28 07:15:36 klomar-Inspiron-3668 influxd-systemd-start.sh[26638]: ts=2021-08-28T06:15:36.178268Z lvl=info msg="Terminating continuous query service" log_id=0WErDlNG000 service=continuous_querier
Aug 28 07:15:36 klomar-Inspiron-3668 influxd-systemd-start.sh[26638]: ts=2021-08-28T06:15:36.178297Z lvl=info msg="Closing retention policy enforcement service" log_id=0WErDlNG000 service=retention
Aug 28 07:15:36 klomar-Inspiron-3668 influxd-systemd-start.sh[26638]: ts=2021-08-28T06:15:36.178701Z lvl=info msg="Closed service" log_id=0WErDlNG000 service=subscriber
Aug 28 07:15:36 klomar-Inspiron-3668 influxd-systemd-start.sh[26638]: ts=2021-08-28T06:15:36.178732Z lvl=info msg="Server shutdown completed" log_id=0WErDlNG000
Aug 28 07:15:36 klomar-Inspiron-3668 systemd[1]: influxdb.service: Failed with result 'exit-code'.
Aug 28 07:15:36 klomar-Inspiron-3668 systemd[1]: Failed to start InfluxDB is an open-source, distributed, time series database.
Aug 28 07:15:36 klomar-Inspiron-3668 systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 358.
Aug 28 07:15:36 klomar-Inspiron-3668 systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
Aug 28 07:15:36 klomar-Inspiron-3668 systemd[1]: Starting InfluxDB is an open-source, distributed, time series database...
Aug 28 07:15:36 klomar-Inspiron-3668 influxd-systemd-start.sh[26710]: Merging with configuration at: /etc/influxdb/influxdb.conf
Aug 28 07:15:36 klomar-Inspiron-3668 influxd-systemd-start.sh[26708]: ts=2021-08-28T06:15:36.544815Z lvl=info msg="InfluxDB starting" log_id=0WErEPO0000 version=1.8.9 branch=1.8 commit=d9b56321d579
Ths seems to be caused by a bug introduced in Influxdb v1.8.7
see: GitHub Issue
I ‘fixed’ it by editing /etc/systemd/system/influxd.service and commenting out Type=forking.
Then:
sudo systemctl daemon-reload
sudo systemctl start influxdb
The influxdb out node now runs without errors.
