Influx 1.8.10, Pi Zero v1, a timeout was exceeded
Hi everyone,
Sorry to bother but I have a problem i can’t solve on my own.
So I have iinflux and grafana running on a pi zero v1 and everything was going fine until I tried to update my distro (DietPi v8.0.2 to v8.1.2).
From what I understood it broke the existing influxdb.service config file in usr/lib/influxdb, preventing the service to start.
First time I simply reburned my SD card with a save and everything went back to normal.
But this morning I saw that the problem came back. Grafana can’t access influx, node red cant either :
“Error: connect ECONNREFUSED ::1:8086”
When i try to stop and start influx i have this message :
dietpi@DietPi:~$ sudo service influxdb start
Job for influxdb.service failed because a timeout was exceeded.
See “systemctl status influxdb.service” and “journalctl -xe” for details.
Here’s the message in journalctl :
Feb 28 11:02:32 DietPi node-red[448]: WARN: Write to InfluxDB failed (attempt: 5). Error: connect ECONNREFUSED ::1:8086
Feb 28 11:02:32 DietPi node-red[448]: at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1157:16) {
Feb 28 11:02:32 DietPi node-red[448]: errno: -111,
Feb 28 11:02:32 DietPi node-red[448]: code: ‘ECONNREFUSED’,
Feb 28 11:02:32 DietPi node-red[448]: syscall: ‘connect’,
Feb 28 11:02:32 DietPi node-red[448]: address: ‘::1’,
Feb 28 11:02:32 DietPi node-red[448]: port: 8086
Feb 28 11:02:32 DietPi node-red[448]: }
My influxdb.service file:
# If you modify this, please also make sure to edit init.sh
[Unit]
Description=InfluxDB is an open-source, distributed, time series database
Documentation=https://docs.influxdata.com/influxdb/
After=network-online.target
[Service]
User=influxdb
Group=influxdb
LimitNOFILE=65536
EnvironmentFile=-/etc/default/influxdb
ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh
KillMode=control-group
Restart=on-failure
Type=forking
PIDFile=/var/lib/influxdb/influxd.pid
[Install]
WantedBy=multi-user.target
Alias=influxd.service
What can I do to stop this problem ? Sorry for language i’m french.
Yesterday all was working fine and suddenly this come from nowhere (no update but one reboot) i’m a bit lost and a newbie so it’s hard for me to figure out what exatcly went wrong.
I have a save of my service file and it didn’t changed. I dont really know how to put it back in place…
Thanks in advance !
Hello @franck_Franc,
Welcome! I see you’re new here.
May I ask why are you using 1.6? That version is very old, just curious. First I would try upgrading to the latest version of InfluxDB
https://portal.influxdata.com/downloads/
You might want to try:
sudo chown -R influxdb:influxdb /var/lib/influxdb
Thanks for the reply !
Actually i use influx 1.8.10 my bad. But that was that. A simple
sudo chmod +x /usr/lib/influxdb/scripts/influxd-systemd-start.sh
then
sudo systemctl start influxdb.service
did the trick
Thanks!
