Since docker image telegraf:1.20.3 I am struggling with permission within a [execd] python script. I included python within the Dockerfile. Python is working within the newly generated container. But the script (to grab SolarEdge API) is generating some files. The script [telegraf log] returned PermissionError: [Errno 13] Permission denied: ‘/etc/telegraf/installinfo’. installinfo is the generated file.
I read this blog post. But where should I do the usermod
or/and chown
Any help is really appreciated.
Regards,
Bert
Hi!
Here is what I would check when creating your docker image:
- Verify that the file itself has the executable bit enabled (e.g.
chmod +x /etc/telegraf/installinfo
- Make sure the script is owned by the
telegraf
user (e.g. chown telegraf /etc/telegraf/installinfo
Those two things should enable you to call the file in your inputs.exec
section of your config.
Let us know if that helps!
Thank you for your fast response.
The file installinfo
is generated by the main Phyton script and is used for caching. I have no clue how to fix it. But I made a working image with Telegraf 1.19.2
Regards,
Bert
