I attempted to upgrade my docker image from 1.8.3 to 2.7.5 and then reset my container to apply the new image. As expected, it failed miserably. It crashes almost instantly so I can’t console into it and I get the following log error:
2024-01-10T14:45:53.529288371Z warn boltdb not found at configured path, but DOCKER_INFLUXDB_INIT_MODE not specified, skipping setup wrapper {“system”: “docker”, “bolt_path”: “/var/lib/influxdb2/influxd.bolt”}
2024-01-10T14:45:53.838038790Z warn boltdb not found at configured path, but DOCKER_INFLUXDB_INIT_MODE not specified, skipping setup wrapper {“system”: “docker”, “bolt_path”: “/var/lib/influxdb2/influxd.bolt”}
Error: unknown shorthand flag: ‘c’ in -config
See ‘influxd -h’ for help
The Influx DB is saved on persistent storage. Is there anyway to revert back to the 1.8.3 image using Portainer? If not, is there a way to create a new InfluxDB container instance based on 2.7.5 and import the data from the 1.8.3 DB? I knew I shouldn’t try to make such a big leap with the DB but it is what it is at this point. My main goal is to not loose all the historic data in the legacy DB.
